Electrics -
Posted: Thu Oct 07, 2010 6:46 pm
Green light on Zig Cf8 went out and didn't re-appear even with new battery - took it in for check - it is working fine but the Battery Status PCB Board needs replacing - Zig still making the Cf8 but don't stock these parts any more apparently. Does anyone know where I could find this part? Can't run to a new Zig at the moment and it is reassuring to know that the battery is ok - miss that green light!
Also, if plugged into mains hook up, can 12volt stuff be used at the same time? i.e. switch Zig to 'On Site' and '12volt on' also?
Whilst I'm on does anyone have a little rocker switch with little red led light which has 4 yellow wires going/coming to/from the Zig - can't find what it is supposed to do - It's on the panel, just below the sink - Westward Leisure were the converters in about 2005/6 - have emailed them but no reply as yet.
Hope that's not too many things at once! Any help on any of them will be gratefully received.
