parking sensors
Posted: Sun Oct 17, 2010 8:13 am
by Micky bluetop
hi guys
i've got a 1999 bongo it's fitted with parking sensors front & rear, and its got a sound control
switch on the dash board, but no idea how it works i've tried pushing the switch in nothing happens
can anybody advise please hav'nt got a clue what to do.
cheers Micky b
Re: parking sensors
Posted: Sun Oct 17, 2010 11:16 am
by lpgimports
check the plug hasnt been unplugged on the back, when its had its speedo converted.
Re: parking sensors
Posted: Sun Oct 17, 2010 1:08 pm
by 321Away
i've seen a round rocker switch fitted the panel to some cars by drivers left knee,that turns the sensors off,or sometimes theres only the rectangle switch marked sonar (for when your in submarine mode! lol)to either side of the steering wheel, do you have the little display on the dashboard?
Julian
Re: parking sensors
Posted: Sun Oct 17, 2010 5:18 pm
by Micky bluetop
hi 321
i've got 1 switch on the left hand side of the steering wheel seems to push in but nothing happens
but i got no display on the dashboard
cheers Micky b
Re: parking sensors
Posted: Sun Oct 17, 2010 6:25 pm
by wormey
Gently pull out that switch and make sure the plastic connector is there and in place. Do you also have a distance meter on the rear roof ?.
When you turn on the sonar button, mine beeps and shows on the LCD screen on the dash and waves going out to show you its working.
Daz
Re: parking sensors
Posted: Sun Oct 17, 2010 10:55 pm
If you don't have a display on the dashboard and the one in the rear then its not a factory fitted system, it sounds more like a 3rd party fit which may have been removed.
See here for the Factory fitted kit
http://www.lushprojects.com/bongopartsm ... 2of03.html
Re: parking sensors
Posted: Mon Oct 18, 2010 1:15 pm
by 321Away
There are 2 types, unsure if both factory fitted, but the 2nd type only has 2 rear sensors and not always a front sensor, and is usually located under the carpet of the passenger footwell (below ecu) and has Mazda stickers all over it, is powered on by a blue/white stripe wire, which is sometimes tied in with stereo/nav equipment when its imported and is sometimes overlooked when its all removed, so pull the passenger carpet up and have a lok underneath, will at least tell you if you have a unit there to start with!
Julian
Re: parking sensors
Posted: Mon Oct 18, 2010 5:31 pm
by Micky bluetop
Hi Julian
thanks for that Julian i'll have look at and thanks everybody for your help
Micky b
