belt tightening HELP
Posted: Sun Oct 31, 2010 11:25 am
by the smoker
hi there you all. can anyone tell me how to tighten the bottom belt . the one with just one belt on on it. ive thought it was the same as the top but it aint. cheers
Gaz
Re: belt tightening HELP
Posted: Sun Oct 31, 2010 12:04 pm
by teenmal
the smoker wrote:hi there you all. can anyone tell me how to tighten the bottom belt . the one with just one belt on on it. ive thought it was the same as the top but it aint. cheers
Gaz
Hi,does this help...............http://www.lushprojects.com/bongopartsm ... no=.html#1
Posted: Sun Oct 31, 2010 1:34 pm
by the smoker
sort of. just cant see it on bongo.
cheers me dear :wink:
Posted: Sun Oct 31, 2010 1:53 pm
by 321Away
you need a 17mm spanner or socket, slip id down the front of the alternator belts and feel for the upper most pulley on the seperate belt,in line with the front of the alternator, about halfway between the engine and alternator and below the alternator (thats a lot of alternators!) there is a 17mm nut that locks it all into place, slacken that a couple of turns and feel up above the pulley and you'll feel a 10mm nut at a right angle to the pulley, get a small ratchet or spanner on this and turn it clockwise, this runs the tension pulley up the thread and tightens the belt, when at correct tension, do up the 17mm and its job done, should take about 10 mins, getting to the bolts can be tricky as they're well hidden, its a job best done by feel ,as its difficult to see them,hope that helps!
Julian
Posted: Sun Oct 31, 2010 1:55 pm
by the smoker
cheers i will go and do it now.
Posted: Sun Oct 31, 2010 4:50 pm
by teenmal
the smoker wrote:sort of. just cant see it on bongo.
Your welcome Duckie :wink: :wink:
