where can i source an oil pump - petrol engine
Posted: Tue Nov 09, 2010 4:45 pm
by kickinthebongos
i reckon my oil pump could be needing replaced. on longer jouneys oil light starts to flicker on and a ticking noise can be heard along with increased engine noise (sounds more like a diesel).
after a break its back to its smooth petrol performane and light doesn't go on. noticed it's very noisey when its a cold start but this goes away after 5 mins
oil level is definitely full checked twice
Re: where can i source an oil pump
Posted: Tue Nov 09, 2010 4:48 pm
kickinthebongos wrote:i reckon my oil pump could be needing replaced. on longer jouneys oil light starts to flicker on and a ticking noise can be heard along with increased engine noise (sounds more like a diesel).
Where do you live?
Not heard of an oil pump going before on a Bongo (I thought they were generally simple robust things that v. rarely failed). Might be best checked out by a Bongo specialist? I wouldn't drive it too much until fault identified. Good luck.
Posted: Tue Nov 09, 2010 4:50 pm
by Northern Bongolow
have you tried an oil flush,or checking the sump strainer (oil pick up) if they have one??
Posted: Tue Nov 09, 2010 5:04 pm
by 321Away
Oil level might be ok but what about the oil itself? have you had it changed/filter etc? I've never known an oil pump to fail (words of doom!),usually oil pumps struggle when the oil is cold/more viscous not once its warmed up?
Julian
Posted: Tue Nov 09, 2010 5:10 pm
Yup, it all seems consistent with oil whose viscosity (thickness) is becoming low as it warms up (old oil, contaminated and/or broken down), and maybe an oil pressure sensor that is a bit tired.
Posted: Tue Nov 09, 2010 6:27 pm
by teenmal
Hi kickinthebongos,
You should get your oil pressure checked,also the by-pass valve.If you are getting a rattle from the engine on high revs It could be wear on main bearings/shaft.You should get higher oil pressure when cold.
Cheers Mal..
Re: where can i source an oil pump - petrol engine
Posted: Tue Nov 09, 2010 11:01 pm
by cheffy34
Check your oil strainer i found horrors in the sump of my v6
but i didn't have a prob with oil feed as such just a prob that i have now got to the bottom of
after taking it to bits
. I have heard of a couple with oil flow to the driver side head on the v6 being a prob
I do believe that Ian had a oil light prob on his maybe he could expand and give his experiances maybe it will shed some light
Posted: Wed Nov 10, 2010 9:22 am
by longhaul8
In a way i hope i am wrong but i had this problem on an old bedford cf van and it turned out to be the big end bearings on the way out. I was told because of the wear on them oil forces its way through which drops the oil presure slightly and results in the oil light filckering on.
Posted: Wed Nov 10, 2010 4:19 pm
longhaul8 wrote:In a way i hope i am wrong but i had this problem on an old bedford cf van and it turned out to be the big end bearings on the way out. I was told because of the wear on them oil forces its way through which drops the oil presure slightly and results in the oil light filckering on.
good point ----now my memory has had a jolt,ive seen this where a failure elsewhere in the engine has led to low oil pressure in the system.
Posted: Fri Nov 12, 2010 6:50 pm
by kickinthebongos
thanks guys got a filter,oil change and flush done. light hasn't come back on yet
there is a whining sound when it starts from cold though. this is a different sound from the tappets and sounds more like when a car is reversing . it lasts a few minutes then disapears and doesn't come back until a cold start again.
Posted: Sat Nov 13, 2010 12:19 pm
by teenmal
kickinthebongos wrote:thanks guys got a filter,oil change and flush done. light hasn't come back on yet
Great stuff,best of luck
Cheers..
