where are the brake lights?
Posted: Wed Nov 10, 2010 3:49 pm
by Sandy
OK - I know that sounds a bit dim, but my brake lights have both stopped working. Don't know if it's a fuse or spent bulbs, but when I went to have a look at the bulbs just now, I realised that I'm not sure where they are. Are they in the cluster incorporated in the rear door, or the one to the outside of that in the main body of the van. I'm astonished that my owner's manual says absolutely nothing about lights and bulbs, and the Factsheet on bulb changing is very cryptic to say the least.
Re: where are the brake lights?
Posted: Wed Nov 10, 2010 3:53 pm
by wonkanoby
they are in outer bits on main body
2 screws then leaver outwards
if both are gone check fuse first
Posted: Wed Nov 10, 2010 7:57 pm
by haydn callow
Also a high level light in the spoiler !!
Posted: Wed Nov 10, 2010 8:06 pm
by mikexgough
Don't forget also that sometimes the brake pedal switch gets "sticky" ......
Posted: Wed Nov 10, 2010 11:25 pm
by Sandy
Thanks guys. The upper brake light on the spoiler is working fine. I'll check the fuse tomorrow, then try the bulbs.
Posted: Thu Nov 11, 2010 1:23 am
by jaylee
I reckon both double filament bulbs gone!
Posted: Thu Nov 11, 2010 8:26 am
by mikexgough
Sandy wrote:Thanks guys. The upper brake light on the spoiler is working fine. I'll check the fuse tomorrow, then try the bulbs.
well that's the switch eliminated then.......... like Jaylee..... my money is on the bulbs...
Posted: Thu Nov 11, 2010 11:45 am
by Sandy
Be gentle with me, Supreme Beings. I am confused. I have removed the light cluster at the rear. It contains three bulbs (side light, reversing light and indicator) all of which are working fine.
So . .um . . where is the brake light bulb?
Posted: Thu Nov 11, 2010 12:05 pm
And one bulb has two filaments;
http://www.lushprojects.com/bongopartsm ... 2of03.html
Its both a 21W and a 5W lamp click the codes by the lamp in the image and it will give you the detail in the list.
Posted: Thu Nov 11, 2010 4:26 pm
by jaylee
It should look a little like this in side the glass...
If you notice it has two filaments inside.. As Geoff said the one bulb does the same job... the filament for the side/tail light works.. But the brake filament in the same bulb don't!
Have you had a tow bar fitted or any electrical work round the back done recently?
Posted: Fri Nov 12, 2010 3:31 pm
by Sandy
Yup - you were all spot on. I have now replaced both bulbs and everything is hunky-dory. And the ABS warning light has gone out.
Many thanks.
