overheating
Posted: Thu Nov 18, 2010 7:29 pm
Hi Guys
got in the bongo this morning drove about a mile, and the engine fan came on about 300yards after that the heater gage
went right across over to the hot so i stopped turned the engine off and left it to cool after cooling down i got it to a garage
where they drained the cooling system flushed it through then they did a pressure test and a vacume test they used some sort of
camera checking hoses and god knows what else. they found that the radiator was all coroded down one side they said this could be the reason for water leak. having only had the bongo 7 weeks i rang Ian Taylor at stoke who got me a brand radiator which is being fitted tomorrow fantastic after care service or what. but my problem is that the guys at the garage who did my pressure & vacume test said it could be something else as well a radiator problems. but when i explained to ian taylor he it was just the sensor on the header tank that caused the engine fan to come even if you've only lost quarter of an inch of water the sensor switch will kick in.
anybody any other ideas
cheers all
Micky b
cheers all
Micky b
