4 pin plug behind blank switch on dash - wots it for?
Posted: Fri Nov 19, 2010 7:12 pm
by maviczap
After succussfully fitting my MPH speedo facia and coolant alarm to my Bongo, I wanted to know what the function of the 4 pin socket behind the blank switch on the dash
On the left there's the rear window heater switch, I know what thats for
But on the right hand side is a 4 pin socket with red and black wires. 4 in total.
It must plug into to an additional switch, is it for the front fog light switch?
Re: 4 pin plug behind blank switch on dash - wots it for?
Posted: Fri Nov 19, 2010 7:16 pm
by haydn callow
I think when Bongos were built they all had more or less the same wiring loom fitted regardless of what extras were going to be fitted..e.g. electric blinds...if a bongo does not have electric blinds the wiring/switchplugs will be in there somwhere....
It would not be a rear foglight as these were never intended to be fitted in Japan...it could be front fog or any number of things....do you have fog lights fitted at the front ??
Posted: Fri Nov 19, 2010 7:19 pm
by maviczap
Its got electric blinds, so its not for those.
I did say is it for the Front fog lights which are fitted to my Bongo as well, although they are broken :D
Posted: Fri Nov 19, 2010 7:58 pm
by haydn callow
I was giving electric blinds as a example ...it could be anything.
The colours of the wires may be of some help
Posted: Fri Nov 19, 2010 8:44 pm
by jaylee
I can tell you that one of the wires is live & one goes to ground on that loom when the side light is on... Try it with a meter!?? Its for the switch back-light when fitted! :wink:
Posted: Fri Nov 19, 2010 8:58 pm
by maviczap
jaylee wrote:I can tell you that one of the wires is live & one goes to ground on that loom when the side light is on... Try it with a meter!?? Its for the switch back-light when fitted! :wink:
Switch back light? One on the tailgate?
Confused :D
Posted: Fri Nov 19, 2010 9:27 pm
by jaylee
Confused :D
When the side lights are on the dash lights up & so do the switches...
maviczap wrote:After succussfully fitting my MPH speedo facia and coolant alarm to my Bongo, I wanted to know what the function of the 4 pin socket behind the blank switch on the dash
& so does one of the wires on this baby... The other one goes to ground... I used the spare connector to power some additional lighting on my dash... :wink:
... At least i think that's what i used it for..?!! :? :lol:
Posted: Fri Nov 19, 2010 9:51 pm
by maviczap
Ah, thats a little clearer now :D
Posted: Fri Nov 19, 2010 9:57 pm
by jaylee
:lol: I just re read what i wrote Richard, quite understandable.... :mrgreen:
I got no idea where the other two wires go though, maybe for a "winter pack" or even a parking pole?? :wink:
Posted: Fri Nov 19, 2010 10:59 pm
The Front Fog light switch has Red with Black stripe and a Black, twice one for the switch itself one for the illumination light and is positioned here as E2-01;
Posted: Sun Nov 28, 2010 5:45 pm
by maviczap
Geoff,
Thanks very much, I haven't taken the dash off again, but pretty sure you're 100% correct.
I'll buy a switch to go with the foglights I won on ebay !
