Warning beep only when passenger door open?
Posted: Wed Dec 15, 2010 7:28 pm
by T9sus4
As my other car turns off the light automagically, I tend to forget to switch my Bongo lights off.
I thought the warning beep was disconnected, as the key-in-ignition beep also doesn't work. However: both warnings work just fine when the passenger door is open, but not when I open the driver side door.
Any thoughts? I found the forum threads mentioning the connector behind the steering column, but I would have thought that turns of the beeps completely not just one one side, right?
Re: Warning beep only when passenger door open?
Posted: Wed Dec 15, 2010 7:55 pm
by MAZABON
does the interior light work when you open the drivers door ?
may be connected to that switch ?
Posted: Wed Dec 15, 2010 8:12 pm
by T9sus4
Just a mo........
............spot on, passenger: yes, driver: no.
Where's that switch located? Can't see it in the dark, must try to find it tomorrow.
Posted: Wed Dec 15, 2010 8:17 pm
by MAZABON
when you open the door, look down and you will see it, looks like a black plastic round peg sticking out, pushes in when the door closes
probably just a dirty contact
Posted: Wed Dec 15, 2010 8:27 pm
by T9sus4
Ah, there's where the button is - I was looking for it on the door, d'oh! #-o
Gotta try twiddling with it tomorrow. Bit dark now.
Posted: Wed Dec 15, 2010 8:57 pm
by jaylee
There's one screw holds it in place so it can earth to the panel... May just need a tighten.?
Posted: Thu Dec 16, 2010 2:13 pm
by T9sus4
MAZABON wrote:probably just a dirty contact
jaylee wrote:There's one screw holds it in place so it can earth to the panel... May just need a tighten.?
You're stars! Spot on, Hoptoad had a screw loose (just like her owner), failing to make contact. I used a slightly thicker screw - job's a good'un! =D>
Posted: Thu Dec 16, 2010 6:53 pm
by MAZABON
well done,
another bongo issue bites the dust :wink:
