new spare banjo filter? is there one on return banjo
Posted: Sun Jan 02, 2011 10:02 pm
by chipvan
What ever i try just can seem to clean mine off fully,
mine has gone kina rusty ish,
also is there one on the return outlet on pump
cheers guys
Re: new spare banjo filter? is there one on return banjo
Posted: Mon Jan 03, 2011 7:48 am
by Dr.Jekyll
Try some Cillit Bang Grime and Lime - put banjo fitter in bottom of cup, spray with the grime and lime stuff and leave for 30 minutes or so. A gentle rub with toothbrush, rinse in fresh water and mine came up like new.
Posted: Mon Jan 03, 2011 3:19 pm
by chipvan
great thanks,tried cola over night but didnt work.
Posted: Mon Jan 03, 2011 4:47 pm
by Dr.Jekyll
chipvan wrote:great thanks,tried cola over night but didnt work.
The acid in the grime and lime is quite strong and eats the brown stuff (you can see it fizzing off....).
Hope it works for you.
Dr.J
Posted: Mon Jan 03, 2011 9:40 pm
by chipvan
i cleaned it with acetone,worked ok but will try your trick next time.thaks for that !!
