Remote locking not working
Posted: Sun Jan 30, 2011 8:50 pm
by tennentj
Hi folks,
My bongo came from Japan with remote locking but it doesn't work anymore. I can hear a noise inside the drivers door when I press the fob but nothng else happens. Is it the actuator,can it be repaired or do I need a new one and does it have to be bongo specific?
Can anyone point me in the right direction of a fix.
Thanks,
Jack
Re: Remote locking not working
Posted: Sun Jan 30, 2011 9:55 pm
by You've Been Bongod
remove the glovebox there is a relay behind the glovebox and thats prob packed in as i had one do that think its the grey relay and can be bought off ebay for around £15
Posted: Mon Jan 31, 2011 12:21 am
It might just be the single added actuator that does the drivers door from the remote, does it work by hand when you press down and lift the internal lock button ? If so its not the relay or the 2 fuses that control the other doors, but the single actuator that is having a problem, might be worth removing the door card and seeing just what is going on.
Posted: Mon Jan 31, 2011 8:41 pm
by tennentj
Hi folks,
Thanks for the replys. It works fine when pressing the internal lock just the remote that is havng the problem. I guess it's the actuator then. I'll see if I can find one on ebay.
Thanks again,
Jack
Posted: Mon Jan 31, 2011 11:00 pm
by MountainGoat
Have you tried via the Breaking Bongos section. Someone there may have an original Japanese one available.
Tony
Posted: Tue Feb 01, 2011 12:20 am
by tennentj
I've tried to pm each of the breaking bongo folk but my messages are still in my outbox. I presume it stays like that until they log in to check their messages.
J
Posted: Tue Feb 01, 2011 10:15 am
by jaylee
If it's a factory fit unit, you could try other similar year Mazda models (626, Eunos/MX5) for the actuator? Even Ford!!??
However, i would look first to see if the actuator gets a pulse from the remote section of the actual receiver, seeing as the manual locking works fine!!??
