Back window
Posted: Sat Feb 12, 2011 7:38 pm
by al & chris
Why is the back window on the passenger side of.. bongo none opening. This is where we want to cook would be good to let all the steam out. Can it be changed to an opening window. There seems to be a latch there but does not open. :?:
Re: Back window
Posted: Sat Feb 12, 2011 7:40 pm
by MAZABON
because of the sliding door i believe :(
Re: Back window
by Barrington
I think its because the sliding door would knock it off??
Re: Back window
Posted: Sat Feb 12, 2011 7:47 pm
by teenmal
Hi al & chris,
Mazda did fit a window with a fan and vent incorporated ( optional extra),try the scrappies they might be some kicking around..
Cheers..
Re: Back window
Posted: Sat Feb 12, 2011 9:10 pm
Yup, this was the modification to get ventilation http://www.lushprojects.com/bongopartsm ... 2of02.html basically the locked window with the top corner cut-out and replaced with a fan!
Re: Back window
Posted: Sat Feb 12, 2011 10:15 pm
by Diplomat
g8dhe wrote:Yup, this was the modification to get ventilation http://www.lushprojects.com/bongopartsm ... 2of02.html basically the locked window with the top corner cut-out and replaced with a fan!
And all because the rear cigar lighter is on the nearside. Wouldn't it have almost been simpler to have put the kitchen on the offside, where the window can be opened, and worked around the power feed problem?
Frank
Re: Back window
Posted: Sun Feb 13, 2011 12:19 pm
by al & chris
Thanks all never even thought of the sliding door so obvious. :oops:
Re: Back window
Posted: Sun Feb 13, 2011 4:16 pm
by rita
And all because the rear cigar lighter is on the nearside. it have Wouldn't almost been simpler to have put the kitchen on the offside, where the window can be opened, and worked around the power feed problem?
Frank
Hi Frank,
Maybe one of these Feng Shui type of things. We no puta cooka dare. :)
Cheers...
