Engine replacement
Posted: Thu Feb 24, 2011 5:23 pm
by jackasti
Apologies to all readers who have a technical ability.
I have a 2.5 TD 4x4 which does all I need it to do however the fuel economy is not great.
I would like a 2.5 V6 Petrol which I would convert to LPG but.... I still require the 4x4 ability.
I understand that there is no such animal as a 2.5 V6 4x4 Bongo.
Is it possible to swop the 2.5 TD engine for a 2.5V6 therefore creating a 2.5 V6 4x4?
Or can a V6 drive train be converted to 4x4?
Are the costs prohibative if it is technically a posibility?
Many thanks
Re: Engine replacement
Posted: Thu Feb 24, 2011 5:32 pm
jackasti wrote:Apologies to all readers who have a technical ability.
Many thanks
It ought to be possible I imagine, but since noone (to my knowledge) has tried it then costs must be hard to estimate. But I reckon they would be enough to make the venture financially unattractive, unless you are a no.1 DIY mechanic, with all the right equipment.
I'm not sure either how plentiful the supply of reclaimed Bongo V6 engine/gearboxes (and all ancillary equipment) might be either, or how you would run the power out to the front diff.
A lovely idea though - I wonder if someone will try it. 8)
Posted: Thu Feb 24, 2011 6:10 pm
by munroman
When I visited Bill at Campercraft I think he said he had created such a hybrid, but it had ended up with a wrecked engine as I think the sump smashed on rough ground.
Depending what you are looking for, I would be inclined to try winter tyres on a 2wd, last winter, when it was very snowy and icy, and I was going some fairly steep places, I only felt the 4wd cut in when I was parking on a very steep spot on a muddy forest road.
Remember lack of ground clearance is one of the Bongos weaknesses.
Posted: Thu Feb 24, 2011 8:25 pm
by soulpaul
what about other engines what would fit with better power and/or fuel rate that you can afford?
and would it stop the head problem?
Posted: Fri Feb 25, 2011 4:16 am
by flossie
Head problem not eliminated but certainly less frequent in a v6 ( hope I'm not tempting fate!)
Posted: Fri Mar 11, 2011 6:10 pm
by jackasti
Very many thanks for all the advice and guidance,
I am now off to see if I can buy a 2.5 V6 conversion to LPG.
Regarding the traction ability of a 2WD and winter tyres....I have recieved plenty of advice and it seems that the Bongo is pretty good in almost all conditions so I have re-evaluated my need for 4x4.
Any one want to swop.....diesel Bongo for LPG Bongo....I thought not.
Colin
Bongonuts have more fun than people.
Posted: Sat Mar 12, 2011 11:59 am
by teenmal
Hi jackasti,
This one is in the for sale section..50+MGP on LPG..
AERO 2001 V6 on LPG 50+ MPG. 4 berth fully loaded Wellhouse Leisure Colour Coded interior. Climate Control, All Electric, Leisure Battery, Tow Bar, Roof Rack, Drive away awning with inner sleep area, +much to much to list. Chasis hammerited & waxoiled. 61K Mot Dec
Be Quick
Cheers..
Posted: Sun Mar 13, 2011 11:44 am
by M 80NGO
If your willing to pay all this out to convert your current van then Why not just get an lpg conversion on your current diesel engine ? it'd make life sooooo much easier, you'll end up with a van who's history you'll know will be more pocket friendly with 4x4 drive.
Just an idea.
