Rear light cluster reflectors
Posted: Sat Feb 26, 2011 10:20 am
by Kincaid
Anyone know if the rear light cluster reflectors on a 1996 can be purchased separately? Our have been taken off along with the plastic spacer that sits between the brake and reverse/indicator light on the same cluster.
Re: Rear light cluster reflectors
Posted: Sat Feb 26, 2011 10:48 am
by jaylee
Hi GK1 are you saying that someone has previously "modded" the modules in the cluster?
Does the tail/break light bleed through to the clear reverse lamp??
Just trying to work out your predicament... Check this link.
http://www.igmaynard.co.uk/bongo/forum/ ... t=rear+fog
Posted: Sat Feb 26, 2011 11:34 am
by You've Been Bongod
sounds like this bongo has had the face lift 99 on rear lights fitted ??
Posted: Sat Feb 26, 2011 11:40 am
by rita
Posted: Sat Feb 26, 2011 12:54 pm
by jaylee
Good point Rita & YBB...
Posted: Sun Feb 27, 2011 9:35 am
by Kincaid
Hi - It's the second one -the missing bits are 51-1A1A and 51-1Y1A. I'm guessing now that you've given me those numbers I should be able to order them from an online shop or Mazda.
Posted: Sun Feb 27, 2011 9:58 am
by Kincaid
Thanks for pointing out that parts catalogue in the members area -I'm still finding my way around all the resources available
Interested to find that I've got the later lights on my van, but it kind of ties in with some other mods I've found -wiring for subwoofers, amps, alarms etc...
