Oil on the air filter
Posted: Thu Mar 10, 2011 11:46 pm
Hi all, I'm worried I may be asking a stupid question but here goes anyway.....
I was preparing to change the diesel fuel pump seals this evening (diesel leaking across the right side of the engine etc). When I took the air filter cover off and removed the internal air filter it was (or appeared to be) full of gunked black oil? I also noticed that the small pipe that runs from the air filter pipe to a sensor to the right of the EGR is broken.
Is it likely that the leaking diesel has been drawn into the air filter?
