Passenger window not working.....
Posted: Thu Mar 17, 2011 2:20 pm
by dext924
this has been happening over a period of time, where it would take longer and longer to go up. Well, it now won't budge. The switches are fine, i think the problem lies behind the panel. I know somewhere on here there are schematic diagrams for all parts of the bongo, but only having looked once I have forgot where it is and can't seem to find it. Could someone please point me in the right direction?
Has anyone had this happen before, and how did you fix it?
Many thanks
Re: Passenger window not working.....
Posted: Thu Mar 17, 2011 2:22 pm
by dobby
dext924 wrote:this has been happening over a period of time, where it would take longer and longer to go up. Well, it now won't budge. The switches are fine, i think the problem lies behind the panel. I know somewhere on here there are schematic diagrams for all parts of the bongo, but only having looked once I have forgot where it is and can't seem to find it. Could someone please point me in the right direction?
Many thanks
It could be breaks in the wiring loom where they passs through the door panel to the door post, quite a common problem
Posted: Thu Mar 17, 2011 2:24 pm
by munroman
I would agree with that, possibly strands in the wire have been breaking one by one and creating resistance hence why the slow operation, till finally they are all broken.
Worth checking that first before going into the oily bits!
Posted: Thu Mar 17, 2011 2:44 pm
by bigdaddycain
Before you start taking things apart, try spraying just inside the inner rubber window seal with some silicone spray... The seal was slowing my passenger window down to the point where it almost stopped moving at all, sprayed it, jobs a good un!
Posted: Thu Mar 17, 2011 5:11 pm
by dext924
Didn't think about the wires. Tried some fairy down the rubber but its just not budging at all now, using either switch.
Will check the wiring at the weekend and see if it is that.
It was working before winter, but not using them for a while, I thought it might have seized or the parts in the door just need a bit of lub. It did work better using the passenger switch, but even that has stopped now.
is the door panel easy to get off??
Posted: Thu Mar 17, 2011 7:40 pm
by MountainGoat
I've had a problem with my front passenger window for some time but can never find the time to have a proper look at it. The window goes down fine from the front passenger switch but refuses to go back up again. However it goes down and up without any problems from the driver's window switch. Any suggestions.
Tony
Posted: Thu Mar 17, 2011 7:53 pm
MountainGoat wrote:I've had a problem with my front passenger window for some time but can never find the time to have a proper look at it. The window goes down fine from the front passenger switch but refuses to go back up again. However it goes down and up without any problems from the driver's window switch. Any suggestions.
Tony
Sounds like it could be a dicky drivers side switch - thats what turned out to be my problem. Does the switch feel a bit loose when you pull it to get the window to come up?
Posted: Thu Mar 17, 2011 9:45 pm
by munroman
mikeonb4c wrote:MountainGoat wrote:I've had a problem with my front passenger window for some time but can never find the time to have a proper look at it. The window goes down fine from the front passenger switch but refuses to go back up again. However it goes down and up without any problems from the driver's window switch. Any suggestions.
Tony
From what Tony says is it not more likely to be an issue relating to the passenger side switch? It seems the drivers side switch is working fine.
Posted: Thu Mar 17, 2011 9:52 pm
munroman wrote:mikeonb4c wrote:MountainGoat wrote:I've had a problem with my front passenger window for some time but can never find the time to have a proper look at it. The window goes down fine from the front passenger switch but refuses to go back up again. However it goes down and up without any problems from the driver's window switch. Any suggestions.
Tony
Sorry - should have read his note more carefully
Posted: Thu Mar 17, 2011 9:57 pm
by munroman
Posted: Thu Mar 17, 2011 10:23 pm
by MountainGoat
