Page 1 of 2
Messed it all up.
Posted: Tue Mar 22, 2011 6:30 pm
by bongobaz
Changed my alternator and aircon belts took ages.
tried to start no ignition no idea what ive done.
Checked fuses main one 100 w looked odd so i pulled it to have a look
and smashed it to bits. What do i do now? feel such a k**b
Re: Messed it all up.
Posted: Tue Mar 22, 2011 6:36 pm
by wonkanoby
Posted: Tue Mar 22, 2011 6:38 pm
by haydn callow
Did you disconnect your starter battery before you started ???? sounds as though you may have inadvertantly "shorted" somthing whilst messing about......pull out the bits of broken fuse and fit a new one....see what happens and report back.
Posted: Tue Mar 22, 2011 6:56 pm
by bongobaz
haydn callow wrote:Did you disconnect your starter battery before you started ???? sounds as though you may have inadvertantly "shorted" somthing whilst messing about......pull out the bits of broken fuse and fit a new one....see what happens and report back.
No i didn't :oops:
I did notice this wire from your wonderful temp gauge and presumed it was damaged when the belt broke. It was all working well up to now but i did move the cable to get my fuse murdering hands in there.
how do i get the old bit out ? they seem like they are pretty solid. Where to get a new one quick? Thanks for the link Wonkanoby.
Posted: Tue Mar 22, 2011 7:03 pm
by haydn callow
That temp gauge cable is a write off....unplug it from the back of the display unit.....unbolt the other end from the cylinder head and send it back to me ....I will try and fix it.
Posted: Tue Mar 22, 2011 7:17 pm
by bongobaz
haydn callow wrote:That temp gauge cable is a write off....unplug it from the back of the display unit.....unbolt the other end from the cylinder head and send it back to me ....I will try and fix it.
Will do Thanks do you think that was the cause?
Posted: Tue Mar 22, 2011 7:19 pm
by haydn callow
Possible but I doubt it.....remove it before trying again.
Posted: Tue Mar 22, 2011 7:50 pm
by westonwarrior
I could be way off here but I was led to believe the 100 amp had to be unscrewd underneath
Posted: Tue Mar 22, 2011 7:54 pm
by waycar8
westonwarrior wrote:I could be way off here but I was led to believe the 100 amp had to be unscrewd underneath
Correct, theres a bolt under neath that goes through the holder and through the 2 copper legs that you see in the picture.
Thats the reason why it just broke when you tried pulling it out Baz :oops:
Posted: Tue Mar 22, 2011 7:55 pm
by jaylee
Baz, 2nd row down, the first fuse.. (Number 9) Blue 15a, in the cab fusebox. Also worth a look in case it blew too..?! :D
by westonwarrior
Yes I got something right mark your calenders it may not happen again for a while
Posted: Tue Mar 22, 2011 7:58 pm
by francophile1947
westonwarrior wrote:Yes I got something right mark your calenders it may not happen again for a while
Here you go Rob ImageImage
Posted: Tue Mar 22, 2011 9:39 pm
by Northern Bongolow
just had a call from baz, hes retired and gone to the pub 8) :lol: .
i will pop him some fuses in the post tonight.
Posted: Tue Mar 22, 2011 10:08 pm
by jaylee
Northern Bongolow wrote:just had a call from baz, hes retired and gone to the pub 8) :lol: .
Fair play! It will all look a lot clearer in the morning.... :wink: 8)
Posted: Wed Mar 23, 2011 10:01 am
by bongobaz
jaylee wrote:Baz, 2nd row down, the first fuse.. (Number 9) Blue 15a, in the cab fusebox. Also worth a look in case it blew too..?! :D
checked No9 fuse all ok. Not sure if i'm pleased with that or not.
Scratching my head now
