Interior Light - fluorescent strip tube
eppiblue
Post by eppiblue » Sat Mar 26, 2011 2:34 pm
Just about to order a replacement strip tube but thought Id ask if anyone has found one of these that emits a more natural/yellow light than the usual cold white light?
'Vincent' - 1996 P reg - Green - 2.5 TD - 4WD - Likes: Diesel, Bitumen and Snow.
Re: Interior Light - fluorescent strip tube
Post by g8dhe » Sat Mar 26, 2011 3:28 pm
Depends which type it is ours is the "U" tube variety and you can get a Warm White http://www.lampco.co.uk/results.asp?sea ... btn=search if there in stock of course :?
eppiblue
Post by eppiblue » Sat Mar 26, 2011 7:11 pm
ah right, mine is the older single strip type... FL6W http://www.b2bfluorescentlights.com/FL6W-EX/T5.htm
Post by g8dhe » Sat Mar 26, 2011 7:47 pm
Would this fit ? http://www.lampco.co.uk/results.asp?sea ... btn=search
its 225mm long and 16mm pitch pins.
eppiblue
Post by eppiblue » Sun Mar 27, 2011 2:40 pm
for £1.63 it's worth a punt... thanks Ill let ya know how it goes.
eppiblue
Post by eppiblue » Sat Apr 02, 2011 12:04 pm
g8dhe wrote:Would this fit ? http://www.lampco.co.uk/results.asp?sea ... btn=search
Perfect, fitted this morning and emits a soft yellow light, about £5 delivered. Thanks for the link!
Post by g8dhe » Sat Apr 02, 2011 12:59 pm
That's great, we got our "U" tube there and a spare as we have a second one mounted in the Cab area to light from the front of the Van in the evenings (we use the footrest seat with a proper seat on it) so it gives much more even lighting and with the warm white its much easier on the eyes for reading and laptop viewing!
