rear tail light goes off when brake is pressed
Posted: Thu Apr 07, 2011 10:32 pm
by Kincaid
Hi - can anyone help with this situation: -
- If the lights are on and I press the brake the rear left light goes off completely (the right works as expected).
- If the lights are not on and the brake is pressed both brake lights come on as expected.
I removed a long wire that was bridging the two front side lights today
Could this be causing the rear brake light issue?
If not, any ideas on the likely cause?
Thanks,
Re: rear tail light goes off when brake is pressed
Posted: Fri Apr 08, 2011 12:25 am
by briwy
Could be a bad earth, that will make weird things happen.
Posted: Fri Apr 08, 2011 7:00 am
by You've Been Bongod
bad earth or wrong bulb
Posted: Fri Apr 08, 2011 3:07 pm
by TechnoTurkey
I'd go on the side of a bad earth as well.
Posted: Fri Apr 08, 2011 4:32 pm
by francophile1947
Definitely a bad earth. I reckon 90% of the old Ford Escorts that I saw, used to suffer with wonky rear lights when braking or indicating
Posted: Fri Apr 08, 2011 7:55 pm
by chipvan
ha ha my dad had an escort van,we called it the disco van for the earth issues you guys are talking about!
Posted: Fri Apr 08, 2011 8:51 pm
by Kincaid
Cheers Gents. I started by reinstating that wire bridging the two front sides - it made no difference
So (as BDC indicated) I went to the back and checked the bulbs. I've got a 1996 but with pimped rear (mark 3) lights. They've been letting in water and the brake light bulb had corroded. So changed the bulb and drilled some holes below the light on the inside to let the water out in the future. Sould all be good now.
Posted: Mon Apr 11, 2011 11:45 pm
by bigdaddycain
Was the rubber washer on that bulb holder shroud Kincaid? The holder should have a fair resistance when you twist it, if it undoes easily the rubber washer may be missing, and could well be the reason the water is getting in the light housing.
Posted: Wed Apr 13, 2011 7:36 pm
by Kincaid
bigdaddycain wrote:Was the rubber washer on that bulb holder shroud Kincaid? The holder should have a fair resistance when you twist it, if it undoes easily the rubber washer may be missing, and could well be the reason the water is getting in the light housing.
Thanks BDC. The rubber washers are in situ but when the lights were upgraded the bulb holders weren't, so a couple are too small for the fittings and (what looks like) plumbers mait has been used
Anyway cleaned it all up at the weekend, used a chisel to create a tight fit between holder and light and then added belt and braces with amalgamating tape. The lights still have condensation in
but I've seen on a previous post of yours that I'm probably going to need to just live with it (or disguise it with pimping veneer)
