Page 1 of 2
What have I done?
Posted: Sun Apr 10, 2011 7:38 pm
by Cobra the 1st
Hello everyone, I'm new to the site and need help. I think that's I've snapped my rear Anti-roll Bar but have limtied to no knowladge regarding this. I have a taken a pic if anyone could confirm or un confirm what I've done and give me an idea of the price I'm looking at I'd be extreamly happy. Thanks
Kris
Re: What have I done?
Posted: Sun Apr 10, 2011 7:40 pm
by westonwarrior
Pic not showing
Posted: Sun Apr 10, 2011 7:53 pm
by Cobra the 1st
Sorry Guys how do I up load a pic?
Posted: Sun Apr 10, 2011 8:00 pm
by westonwarrior
follow the instructions here http://www.igmaynard.co.uk/bongo/forum/ ... =42&t=9285
or if you can uplaod it to a web package just put the link or if all that fails shout and I will pm my e-mail and you can send it me and I will post it
also where abouts are you as local knowledge may help any advice
Posted: Sun Apr 10, 2011 8:05 pm
by Cobra the 1st
Ok I can't figure it out. Basically it looks like a pipe behind the rear wheels, it looks like it's severed and I'm guessing it's the rear anti roll bar. Wish I could show the picture! If it is could anyone tell me how much is new one roughly??
Posted: Sun Apr 10, 2011 8:20 pm
by westonwarrior
OK here is the pic
Itsnot the anti roll bar that sits just in front of the rear axel
Posted: Sun Apr 10, 2011 8:27 pm
by mikexgough
The bar to the rear of the diff is the Lateral rod....
Posted: Sun Apr 10, 2011 8:31 pm
by francophile1947
The bottom of the shock absorber doesn't look as if it's attached to anything :? :?
Posted: Sun Apr 10, 2011 8:33 pm
by westonwarrior
It may be but in lush projects it looks like its attached to the axel in the photo it doesn't
http://www.lushprojects.com/bongopartsm ... 1of02.html
Posted: Sun Apr 10, 2011 8:44 pm
by westonwarrior
I think your right John that does not look good
Posted: Sun Apr 10, 2011 8:51 pm
by mikexgough
This is what it does scroll down and play the flash animation
Posted: Sun Apr 10, 2011 8:52 pm
by scanner
The broken bit is the "Panhard Rod" which is there to stop the rear axles swing from side to side on corners.
http://en.wikipedia.org/wiki/Panhard_rod
And yes it doesn't look like the nearside shocker is attached as it should be either.
What on earth did you hit?
Posted: Mon Apr 11, 2011 7:20 am
by mikexgough
Some photos......
Nearside - Image
Offside - Image
Nope not my Bongo :D
Also..... Part No S10H28650 Lateral Rod......
I guess one the usual Bongo specialists may have a r=good s/h rod, but before you sort one, I would find out what caused the fracture/bend and if indeed it's connected as per the above photos....
Posted: Mon Apr 11, 2011 10:53 am
by jaylee
Like you Kris, i have a limited knowledge of these matters... But like Scanner am quite interested how this damage came about..?
I'm looking at this picture & also thinking possible damage to any bearings..? & could that be brake fluid on the inner wheel rim?? :idea: Techies knock me back if i appear to be wrong, I'd check the tire walls too!??? Cant be too careful... :D
Posted: Mon Apr 11, 2011 1:06 pm
by AlliDelta
I can probably get you a panhard bar off the Bongo I'm breaking if you want...
