GPS Vehicle Tracker
Posted: Sun May 01, 2011 4:21 pm
by dandemann8
Just found this little gizmo,
No monthly fees.
Track any time.
Remote immobilise.
Trace on Google maps.
Easy DIY fitting.
And best of all NO MONTHLY CONTRACT.
http://back2you.com/store/product_info. ... duct_id=52
Order online and enter MMM33 for 10% discount.
Re: GPS Vehicle Tracker
Posted: Sun May 01, 2011 4:42 pm
by helen&tony
Mmmmm...that does look useful. Didn't I hear that a few organised thieves have a way for "sweeping" for such devices?...I am very tempted, however!
Posted: Sun May 01, 2011 6:18 pm
Julian from 321Away brought these to our attention on another thread, and available v. cheap on ebay. See this thread:
http://www.igmaynard.co.uk/bongo/forum/ ... t=Security
I've been trying to get more views on the best one/type to buy and posted recently on that thread, but I'll repeat it here as no-one is answering me on that thread :(
Still thinking about buying and installing a GPS/GPRS/SIM tracking device. Feedback for (Chinese) sellers of the product Julian has mentioned has a few bad scores, so I'm looking around ebay and have found (cheaper) alternatives:
£45 http://cgi.ebay.co.uk/Vehicle-CAR-TRACK ... 41578ce64a
£58 http://cgi.ebay.co.uk/OEM-TK102-2-GSM-G ... 45f987ed06
£biddable http://cgi.ebay.co.uk/Car-Realtime-GPS- ... 4aaa98cd59
This looks like the device Julian referred to earlier. Its not clear to me whether you wire these direct from the car battery or whether (like the other ones I've just listed) they have their own internal li-ion battery which you have to charge using some kind of charging device.
£55 http://cgi.ebay.co.uk/GPS-TRACKING-SYST ... 4aaab08a10
This also looks like the one Julian recommends, but with a London seller and (unlike other suppliers) no suggestion that import duties may be added. Product description is poor but I'm guessing that it is the same model and that it does all the alarm/immobiliser things that other similar looking ones do.
Finally, I'm trying to work out what siginificance of wiring into door opening switches is (Julian mentions this, and some adverts do to). I presume that this is becuase the assumption is that the device should be active whenever the car door is closed, and that you can then use the tracker devices immobiler function to cut of fuel etc. if you are alerted that the vehicle has moved off without authorisation.
But would it not be simpler (wiring wise) and more robust to:
1) immobilise the vehicle via a concealed switch or somesuch, when you leave the vehicle unattended.
2) Using the same switch (or a separate switch, if you want extra hidden switches), set the tracker device to 'on' at the same time as it activates immobilsation. You could still use the trackers immobilisation feature to disable a critical component if the thief manages to over-ride the primary immobilsation device.
I'd be interested in any thoughts on the above & thanks (we might all find it interesting to pursue this debate a little further :roll: ).
Mike 8)
PS - I see some of these devices have microphones so you can listen to what' going on in the car. But I imagine these are little more than a gimmick, not worth considering over the other core features?
_________________
I Bongo, therefore I am...
Bongoing, BonGoing, BonGone
Posted: Mon May 02, 2011 10:39 am
by 321Away
Hi Mike, when i've installed them, ive always connected the door pins, same as when installing an alarm, in that case its the first line of defense, but in the trackers it sends out a first alert, assumedly to alert you that the vehicle has been opened, not much use if your not in the vicinity of the vehicle! Not sure what you mean about the door bit? the system can be armed at any point and if its on par with most systems now it should ignore the doors if they are open already, as it should only recognise a change in state. I do find it curious that it has so many 'layers' of defense, first perimeter (doors), then igntion (hotwiring) and finally movement, an advantage or possibly disadvantage depending on how you see it, is the unit doesnt have a visual indicator, which means an intruder doesnt know the systems been triggered but at the same a thief would have no deterrent from attempting to break in.
An immobiliser is just an electronic secure switch, so fitting a simple throw switch is exactly the same thing, i've had lots of customers who have wanted a switch fitted to their car using an original manufacturer switch so it blends in, could use the engine pre-heat switch and wire so it has to be on before the car will start??
the trackers i've fitted are activated by sending them a coded text, if they were powered down and them back up, they boot into the unarmed state, and not sure if the ignition detect wire, prevents it from being armed once the vehicle is started?
Agree the whole mic thing is a bit odd, the whole units are more likely to be used for spying on people rather than tracking a vehicle!
Julian
Posted: Mon May 02, 2011 11:49 am
321Away wrote:Hi Mike, when i've installed them, ive always connected the door pins, same as when installing an alarm, in that case its the first line of defense, but in the trackers it sends out a first alert, assumedly to alert you that the vehicle has been opened, not much use if your not in the vicinity of the vehicle! Not sure what you mean about the door bit? the system can be armed at any point and if its on par with most systems now it should ignore the doors if they are open already, as it should only recognise a change in state. I do find it curious that it has so many 'layers' of defense, first perimeter (doors), then igntion (hotwiring) and finally movement, an advantage or possibly disadvantage depending on how you see it, is the unit doesnt have a visual indicator, which means an intruder doesnt know the systems been triggered but at the same a thief would have no deterrent from attempting to break in.
Julian
Great advice Julian, as ever. I'll keep it on file for if/when I fit one of these gizmos
Mike 8)
PS - strange - I thought I'd replied to this post earlier, but can see no trace :?
Posted: Mon May 02, 2011 1:16 pm
by helen&tony
I'm looking at changing my alarm, as I only have one working remote...and looking around, I see one make offering a pager that signals your mobile phone in the event of break-in....It is a unit available as an add-on (not mentioning make for security reasons)...sounds quite reasonable....I am torn over the issue of remotely operated cutouts in the event of theft...a bit dangerous if the immobiliser cuts the engine as the thief moves into fast traffic...a recoverable theft might well resulting a write-off instead, or, worse still, such a cutout could result in a death, and the owner getting prosecuted for causing it...????
Posted: Mon May 02, 2011 2:10 pm
by 321Away
alarm/remote cut outs should only occur if the vehicles ignition system isn't activated, ie if the igntion is on, you cant turn your alarm on (try it, if you can your alarm isnt installed properly!!), the pager system is no different from your alarm, either could have bad results if the immobiliser kicked in at the wrong time, but i get that your saying what if you activate the cut out and cause the accident? Now thats a topic for discussion!
Julian
Posted: Mon May 02, 2011 2:34 pm
by helen&tony
Hi Julian
Yes...indeed a tricky subject...mostly applicable to the "Anti-Jack" facility that's increasingly popular. I would suspect that a remote LCD pager type may be able to perform this cut-out while the ignition is on, as that would, I suspect, be what the "Anti-jack" facility is all about...but you know more about alarms than me....
My fear of legal proceedings in a matter like this is because a thief can take action, and the police for that matter, if a property, be it house or car , could be rendered unsafe as a way of injuring a victim. It would even stand here, as the law says you have a right to defend yourself if an assailant is coming for you armed, but not if they are retreating...so...correct me if I'm wrong, but a thief taking your car away from you is retreating.
There is also the secondary issue of injury caused to another party if your car became switched off and caused an injury to someone in another car or a pedestrian....The whole thing is a ticking time-bomb as far as I see it...
Tracking is something else!...Can they , in fact, be blocked by a signal?
