Help with Over heating and starting
Posted: Fri May 06, 2011 4:06 pm
Recently back from a holiday in Cornwall - lovely time etc but had a couple of problems with the Bongo.
Firstly I had an overheat - never had a flicker from the temp needle before but started to rise rapidly when set off on a trip to Post Issac. Pulled over just as it I heard water escaping from the header tank and called Green Flag. Guy turned up, no obvious water loss from anywhere and fans/belts all fine. Topped up the water,whipped out the bleed pipe (something i never even knew existed!) and proceded to do a an improptu bleed. All fine for the rest of the week about 350km)! Day before due to come back same again, needle starting to rise. I read up about bleeding on here and did some of my own. All fine again until i was back home (again about another 350km). Did another bleed and temp was fine again on next run. Not used it this last week but checked radiator level last night and had to top up with 1.5l to to top.
Any ideas whats going on? Again no obvious water loss from anywhere. Does is still sound like the coolant system isnt full and/or has airlocks?
Secondly,while away inbetween all of this i started to have some starting problems. Turn ignition, all lights are on,turn to start and nothing. All lights go off, fans off but engine didnt turn. A few more turns and pedal and eventually it starts. Has become more frequent since it first happened. Though it was battery at first but thats fully charged. Think its related to the overheat? Or is it glowpulgs/starter motor?
Have had a read of varioustopicson here but cant pinpoint what my problems are for certain- any advice would be greatly appriciated.
Dave
Dave
