Page 1 of 2
Engine temperature pop quiz!
Posted: Mon May 09, 2011 8:10 pm
by jaylee
If i was to point a digital engine temp gauge meter at the engine at point blank range to get a general/average temp...
Would it be here..? (outlined in red.)
Re: Engine temperature pop quiz!
Posted: Mon May 09, 2011 8:31 pm
by waycar8
80 degrees?
What do we win if we get it right 8)
Posted: Mon May 09, 2011 9:16 pm
by jaylee
waycar8 wrote:80 degrees?
That pretty much depends on what (if at all) i have to pull out if i have a problem... :lol:
I'm running my Mason modded gauge at about here...
I'm getting a reading of 88 degrees on the digital read out... I read that the Mason modded temp pictured above should be meaning around 95...
That's roughly how it sits ticking over in traffic, it drops lower down hill & can climb half way again from the max on Widdowsons example when steep hill inclines & batting it... :wink:
Posted: Mon May 09, 2011 9:25 pm
by waycar8
Mine sits around the same mark also (1 o clock mark) but whilst driving up hill's or with a bit of load, but can see it drop to the 12 oclock mark when the stat open's or the (fans kick in) whilst normal driving or stationary, and then see it rise hard to the 2 o clock mark on the motorway pushing it hard in nice hot sunny weather, no idea what the temperature read's in degrees :lol:
Posted: Mon May 09, 2011 9:54 pm
by jaylee
I don't think i've ever noticed my fans cut in...?!! Unless the AC is on...
I got a bit more time on my hands tomorrow... Gonna be having a general poke about with this...
After a bat up the A46! :D
Posted: Mon May 09, 2011 9:57 pm
by waycar8
jaylee wrote:I don't think i've ever noticed my fans cut in...?!! Unless the AC is on...
Does that have the red laser thing that you point?, Ive seen them advertised for reptiles for checking the temps in the vivs but never bought one, toooooo expensive
Posted: Mon May 09, 2011 10:03 pm
by jaylee
:? I thought it was worth a punt.... Paid for & received within 23 hours...! :wink:
http://cgi.ebay.co.uk/Digital-Infrared- ... c6ffaa6679 :mrgreen:
Posted: Mon May 09, 2011 10:07 pm
by haydn callow
I wouldn't point it at the exaust side.....(heat from exaust)
Point it at the top hose under the drivers seat where it exits the cylinder head
Posted: Mon May 09, 2011 10:11 pm
by jaylee
:idea: #-o Cheers Haydn! =D> I was planning a radiator scan too... The one behind the front AC evaporator thing..! [-X :lol:
Posted: Mon May 09, 2011 10:38 pm
by dobby
We are probably going to get into lots of hot water with the temperature boffins but my mason modded gauge sits a bit lower than that and runs at 88 to 90 degs according to the TM2 which has it's sensor on the back of the head.
Posted: Mon May 09, 2011 11:11 pm
by jaylee
dobby wrote:We are probably going to get into lots of hot water with the temperature boffins but my mason modded gauge sits a bit lower than that and runs at 88 to 90 degs according to the TM2 which has it's sensor on the back of the head.
I'm quite happy for the feed back! 8) That was what i was getting off the exhaust side.... ](*,) :-s
Posted: Mon May 09, 2011 11:13 pm
by dobby
Have I confused matters :roll:
Posted: Mon May 09, 2011 11:34 pm
by jaylee
dobby wrote:Have I confused matters :roll:
Not at all... :D I've always had a theory about these modded gauges.. & why they might have been damped up in the first place! :wink:
Posted: Mon May 09, 2011 11:39 pm
by dobby
8-[
Posted: Mon May 09, 2011 11:58 pm
by jaylee
Fact + doubt = :?:
Will let you know how i get on.... Believe! 8)
