Tail gate lift
Tail gate lift
Hi All,
I've recently fitted a Thule bike rack and very happy I am with it too.
Question is though, with the bikes off the rack the tail gate wont stay up on it's own, do I need new gas struts? it was fine before...
Cheers, Charlie
Cheers, Charlie
"I tried jogging once but the ice kept falling out of my glass" Dave Lee Roth
- hembramacho
Re: Tail gate lift
I've just done the same, and got the same problem. Thinking of re-gassing the struts. Anyone done this with success?
Andrew
Andrew
Re: Tail gate lift
I got mine regassed here:
http://www.sgs-engineering.com/pages/Regassing-Service
While you wait service if you're local.
Mine were just generally tatered but as we've got a bike rack on the tailgate I asked about upping the pressure. The guy there wasn't sure but said he doubted the struts would take the extra pressure. Might be worth asking again though.
If you take the struts off make sure the tailgate is well supported first. Its amazingly heavy.
Re: Tail gate lift
Well that seems easy enough, Cheers Briwy, I'll give that a gobriwy wrote:I got mine regassed here:
Re: Tail gate lift
Hi charlieD,charlieD wrote:Hi All,
Cheers, Charlie
I would say that you need to upgrade the struts to compensate fot the extra load.If you load the tailgate with your bikes etc then using a set of scales,place a piece of wood or similar between the fully open tailgate and the scales on the ground to get the weight of the load.This will give your supplier an idea of the strength of struts that you require.
Remember without the load the tailgate will be a wee bit stiff to close..
Cheers.
- hembramacho
Re: Tail gate lift
Had my new gas struts back today from SGS and just re-fitted them. Problem sorted. The tail gate now stays put with the bike rack still attached. (minus bikes obviously!)
I had to go for new struts in the end, as my original ones weren't up to a re-gas apparently!
A few pics:
Andrew
A few pics:
Andrew
- daveblueozzie
- hembramacho
Re: Tail gate lift
£151.54!daveblueozzie wrote:How much for the new struts ?
Expensive I know - a re-gas of the original struts would have been £50 - but having camped with the tail gate propped up with a pole, and knowing how my kids run about not looking where they're going, all it takes is that pole to get knocked by one of them, and having felt the sheer weight of the tail gate, I don't think I could live with the possible consequences!!
Andrew
- daveblueozzie
Re: Tail gate lift
I noticed when you were parked next to me in Wales the other weekend that you were using a pole to hold the tailgate up, NOT SAFE.
A cheap solution to save the kids from getting hurt.
Lost without my Bongo.
- hembramacho
Re: Tail gate lift
Thanks Davedaveblueozzie wrote:I noticed when you were parked next to me in Wales the other weekend that you were using a pole to hold the tailgate up, NOT SAFE.
That was the first (and only) time we went camping with the tail gate like that. After doing that the once, totally agree it's not safe at all and needed to do something.
As I said before, I dread to think what could have happened in the event of a misshap, so totally sorted now - very pleased.
Andrew
Re: Tail gate lift
we still use a walking stick to keep our tailgate open so we are naughty too.
Re: Tail gate lift
Ordered mine today, eventually got fed up holding the tail gate open with my head while trying to reach in and grab the hook up cable
Re: Tail gate lift
I just don't use the tailgate (don't really have a need to and can't say I miss it).
If there wasn't a chance that I might be moving abroad though I think I'd be going down the same route as Andrew just for the odd occasion I need to get something big in the back.
Re: Tail gate lift
Are you a member of the fun police or something?daveblueozzie wrote:I noticed when you were parked next to me in Wales the other weekend that you were using a pole to hold the tailgate up, NOT SAFE.
