bongo front wheel clunk
Posted: Mon May 23, 2011 10:37 am
by Meadow1812
i bought a 1999 facelift 2.5 diesel 4x4 bongo in january and love it apart from clunk noise that comes from drivers side front wheel whenever you drive over an uneven bad piece of road. as was under warranty i asked dealer to check out and he gave it the all clear. it is doing my head in ! can anyone give me any advice on this problem ? regards barry :?:
Re: bongo front wheel clunk
Posted: Mon May 23, 2011 11:40 am
Meadow1812 wrote:i bought a 1999 facelift 2.5 diesel 4x4 bongo in january and love it apart from clunk noise that comes from drivers side front wheel whenever you drive over an uneven bad piece of road. as was under warranty i asked dealer to check out and he gave it the all clear. it is doing my head in ! can anyone give me any advice on this problem ? regards barry :?:
Sounds like front drop links and/or anti-roll bar bushes could be the problem. Simple fix if so, but I don't like the way the dealer just dismisses it as normal. Where are you based, as there may be an independent Bongo specialist near you that you culd get an independent opinion from.
Posted: Mon May 23, 2011 12:18 pm
by mikexgough
Agree with that Mike.... seen it before where sometimes there looks to be no wear or little play in the links and bushes but when you drive it you pick up on it......if it is them then it's a good opportunity to change all components connected with the roll bar......
I guess if someone local can confirm to Meadow1812 that links/bushes etc is the problem then he/she can take the findings to the dealer and ask if they will change the offending item or if not request that they pay for the work to be done/parts purchase....
Posted: Mon May 23, 2011 1:34 pm
by 321Away
put the car on full lock and which ever side you can get your hand behid the wheel (so offside for left lock, nearside for right), you'll see the drop link bolted to the shock absorber, reach round the back of the drop link and grab it at the top where it bolts and try to wiggle it left and right, if there's any movement then they need replacing, make sure you get the anti roll bar bushes done at the same time, should be all under warranty.
Julian
Posted: Mon May 23, 2011 1:37 pm
by helen&tony
If it's only one side, it's usually lower ball-joint/ wishbone bushes (or droplinks/ anti-rollbar bushes)
Posted: Mon May 23, 2011 2:08 pm
And when they change the anti-roll bar bushes, make sure they put new steel u-brackets on too. Costs peanuts, but the old brackets often give up the ghost when put back on with new bushes (metal fatigue + strain of holding/compressing new bushes).
Posted: Tue May 24, 2011 7:48 am
by mikexgough
321Away wrote:put the car on full lock and which ever side you can get your hand behid the wheel (so offside for left lock, nearside for right), you'll see the drop link bolted to the shock absorber, reach round the back of the drop link and grab it at the top where it bolts and try to wiggle it left and right, if there's any movement then they need replacing, make sure you get the anti roll bar bushes done at the same time, should be all under warranty.
Julian
=D> =D> =D> If members follow this excellent description then there will be less posts on Drop links and less MOT failures for the same.... :wink:
Right...better go ....stop waffling and get this 71 Fiat 500 up for it's MOT....... Kingpins... #-o
Posted: Tue May 24, 2011 12:13 pm
by bigdaddycain
mikeonb4c wrote:And when they change the anti-roll bar bushes, make sure they put new steel u-brackets on too. Costs peanuts, but the old brackets often give up the ghost when put back on with new bushes (metal fatigue + strain of holding/compressing new bushes).
I was just about to say the same thing Mike! I had the clunks some years ago... new bushes on the ARB didn't cure it... Hairline fracture in the ARB bracket (one of) :shock: A new set of brackets cured the clunk. :D
Posted: Tue May 24, 2011 7:46 pm
by Meadow1812
i would just like to say a big thankyou to mikeonb4c, mikexgough,321away,helen&tony and bigdaddycain for taking the time to give me information i was needing much appreciated guys regards barry louise and meadow [new bongo converts]. =D> :D
Posted: Tue May 24, 2011 9:09 pm
Meadow1812 wrote:i would just like to say a big thankyou to mikeonb4c, mikexgough,321away,helen&tony and bigdaddycain for taking the time to give me information i was needing much appreciated guys regards barry louise and meadow [new bongo converts]. =D> :D
No worries (well plenty actually, but thats not your problem :lol: )
Oh and have you fitted a low coolant alarm? V. strongly advise it if you haven't
