Ta.
I've been having intermittent problems with my autogearbox not going into 4th gear. Fault codes i'm getting are 16 and 62. EGR position sensor and Overrunning clutch solenoid.
Today i took it to a Autogearbox specialist in Pontypridd. He took it for a spin and couldn't find anything wrong, which i new as i's explained it was an intermittent fault. He seemed reluctant to change the solenoid pack because of this code 16 i keep getting. Any advice on what's causing this code 16? Or will just changing the solenoid pack solve the problems. There is another gearbox specialist fairy local i might go to and see if they can shed any light on it. It's Diesel 4wd 1996.
