Page 1 of 2
Lurking behind fuel pump.?
Posted: Thu Jun 23, 2011 12:22 pm
by jaylee
Anyone know what this is? I found it hanging loose behind the fuel pump on my pre travel checks, thought something was disconnected... So pulled it out & took some snaps!
The 2 wire loom run up to this block connector above the pump..
I have put it here out the way for time being...
Re: Lurking behind fuel pump.?
Posted: Thu Jun 23, 2011 12:24 pm
by missfixit70
I think it's for the optional flux capacitor
Posted: Thu Jun 23, 2011 12:27 pm
by jaylee
missfixit70 wrote:I think it's for the optional flux capacitor
I would have thought the loom would have been longer & run to just behind the cab at the back??
It would also need about 1,210,000,000 watts of power...
Posted: Thu Jun 23, 2011 12:44 pm
by missfixit70
May explain Allifriendee's current drain?
Posted: Thu Jun 23, 2011 12:55 pm
by jaylee
It can't be some bypass for the "fly by wire" set up, can it??
Mines a 95.. & just been trawling through Lushy P.
Posted: Thu Jun 23, 2011 7:28 pm
by Diplomat
I've no idea what it does but I can tell you where it's meant to be, rather than hanging loose!
Get a mirror and look in the area between the pump and a nearby vacuum device and you will find a slot fixed to the metalwork that the mistery device slides into (using the grooves just visible on its right hand flat side as viewed in the lower photo or the uderside as viewed in the top photo).
It falls out quite easily, possibly due to vibration. Refit it from the rear towards the front. Get it straight before pushing as forcing it could damage the fragile plastic.
My first thought was that it was some kind of knock sensor or similar and it needed to be in contact with something.
However it doesn't seem to affect the performance if it is hanging loose. Maybe it is just good practice to have it secured.
Love to know what it is for, though!
Frank
Posted: Thu Jun 23, 2011 9:24 pm
by jaylee
Posted: Thu Jun 23, 2011 9:51 pm
by Diplomat
Slots.
that's the word I was looking for.
All we need now is someone who knows what it is!
Frank
Posted: Thu Jun 23, 2011 10:46 pm
by jaylee
It could have something to do with the vacuum solenoids..??
Geoff would know..! Been through the Lush pages & stumped if i know..?!!
Posted: Thu Jun 23, 2011 11:11 pm
by Northern Bongolow
Posted: Fri Jun 24, 2011 12:22 am
Posted: Fri Jun 24, 2011 7:07 am
by helen&tony
Hi Mike
Wrong song....here's what you're looking for:
http://www.youtube.com/watch?v=-tT_YO16lbU
Posted: Fri Jun 24, 2011 7:41 am
by corblimey
I know what it is. Do I get a prize?
Posted: Fri Jun 24, 2011 8:15 am
by jaylee
corblimey wrote:I know what it is. Do I get a prize?
Fergodsakes, just tell us!!??
Posted: Fri Jun 24, 2011 8:31 am
by corblimey
Unfortunately it's not a flux capacitor..... it's a T.P.S.C.R or Throttle Position Sensor Compensation Resistor for short.
