				Gear box problem advise required
				Posted: Fri Jun 24, 2011 8:41 pm
				by M 80NGO
				Hi my bongo has been off the road for just over a week now having the fuel pump inner seals replaced, now its all back together i seem to have aquired a slight gear box issue, it was fine before it was parked up and all gears engage forward and reverse but now if i pull away in drive it won't change gear it just revs higher and higher until 4000 rpm at which point it will change up, if i push the hold button so the hold light on the dash comes on then it changes gear fine and drives as it should then after a while the hold light starts flashing, i can only assume its summat simple as it was working fine before and the gearbox oil levels are ok tho i did give it half a litre to bring it back to the max mark, oil level was checked with the engine running and in Neutral.
Any info will be greatly recieved, Pete.
				Re: Gear box problem advise required
				Posted: Fri Jun 24, 2011 8:47 pm
				by lazyb5
				Hi, if they were working on the fuel pump check your throttle position sensor it affects when the box changes up. That sabout all i can think of they may have even forgot to connect it although i would have thought the hold light would flash from the start. I`ll see if i can find the thread about the TPS for you.
				Posted: Fri Jun 24, 2011 9:03 pm
				by M 80NGO
				lazyb5 wrote:Hi, if they were working on the fuel pump check your throttle position sensor it affects when the box changes up. That sabout all i can think of they may have even forgot to connect it although i would have thought the hold light would flash from the start. I`ll see if i can find the thread about the TPS for you.
Thanx for the input where is the throttle position sensor located ?
				Posted: Fri Jun 24, 2011 9:07 pm
				by Diplomat
				Maybe the T.P.S.C.R. has come adrift.
http://www.igmaynard.co.uk/bongo/forum/ ... 54&start=0
4000 rpm on a Bongo sounds horrendous.
Frank
				Posted: Fri Jun 24, 2011 9:08 pm
				by lazyb5
				http://www.igmaynard.co.uk/bongo/forum/ ... nt#p161814
Hope that helps cant think it can be anything else
 Ooh that doesnt show where it is its right on top of the diesel pump.
its the thing at the top with a star on it.
				Posted: Fri Jun 24, 2011 10:35 pm
				by M 80NGO
				Posted: Sat Jun 25, 2011 12:20 am
				by lazyb5
				Excellent see you there tomorrow i`ll be there about 12 ish
