Cleaning
Posted: Mon Jul 04, 2011 4:54 pm
by rita
The outside of the tent has some grease/oil marks on it,any recommendation's on how to clean it..thanks.
Re: Cleaning
Posted: Mon Jul 04, 2011 5:08 pm
by bigdaddycain
The tent on the freetop? I use a weak solution of warm TFR sprayed on a closed tent, then "waft" jetwash off again... I use neat TFR on the lower sections that stain due to the freetop struts. Thorough rinsing is essential though... :shock:
Re: Cleaning
Posted: Mon Jul 04, 2011 6:27 pm
by rita
bigdaddycain wrote:The tent on the freetop? I use a weak solution of warm TFR sprayed on a closed tent, then "waft" jetwash off again... I use neat TFR on the lower sections that stain due to the freetop struts. Thorough rinsing is essential though... :shock:
Hi thanks for the info,I will try TFR.
Re: Cleaning
Posted: Mon Jul 04, 2011 6:34 pm
by bigdaddycain
No worries. If the worst of the staining is the good old strut stains then i'm pretty sure a mild degreaser should take care of it if the TFR won't touch it... Mine has only ever had very light stains, others i've seen have looked pretty engrained.
Re: Cleaning
Posted: Mon Jul 04, 2011 7:08 pm
by mikexgough
Flash spray does it too.......
Re: Cleaning
Posted: Mon Jul 18, 2011 4:12 pm
by rita
mikexgough wrote:Flash spray does it too.......
Used the flash it removed the black grease stains no problem but there is a lowdown yellowish steak (excuse the pun)that is proving to be very stubborn so far.
Cheers..
Re: Cleaning
Posted: Mon Jul 18, 2011 5:29 pm
by wonkanoby
