SHOCKS?
Posted: Mon Jul 11, 2011 9:59 pm
by cardiff996
1998 - R Reg - 63K miles.
How can I tell please if new shocks are needed?
due to my job I have a car every 2 - 3 years, so there is now way I can compare the Bongo to how modern cars perform.
To me it feels a bit harsh over some pot holes and the rear does'nt seem to cushion some of the speed bumps etc. As you go over your allways waiting for the BUMP!
Dont think its bottoming out though.
Thanks gang for any advice on what to look for.
Re: SHOCKS?
Posted: Tue Jul 12, 2011 12:00 am
by Northern Bongolow
if your getting a bump then your springs may be weak as well as the shocks.
ive just made a set of rear softer hitting bump stops to help with the thumping.
to test your shocks shove down hard and watch the recoil,it should be damped very quickly.
a mate has just replaced back and front struts/shocks(not springs) and recons it has transformed his motor. it now doesnt wallow on/off roundabouts,and is better around his speedbump infested town now.
non of his were showing signs of leaking, he just felt is was handling poorly.
Re: SHOCKS?
Posted: Tue Jul 12, 2011 1:37 pm
by cardiff996
Thanks Northern, will give it try.
I think new shocks will have to wait until next years budget, but I definatley think the handling would be improved.
Cheers again
Re: SHOCKS?
Posted: Tue Jul 12, 2011 3:07 pm
by rita
I always thought that shock absorbers should be renamed Rebound Arrestors.
Cheers.
Re: SHOCKS?
Posted: Tue Jul 12, 2011 3:17 pm
by snow_kiter
FYI
New rear shocks were sourced from a Mazda dealer at around £66 each.
New fronts are around £85 each from Mazda but had a very long lead time for delivery. Sourced from Ebay @ £169 for the pair.
Handling has improved tremendously. Used to drop off speed bumps with a couple of rebounds but no more. Has eased the lean on cornering and braking has improved due to a lack of vibration.
Re: SHOCKS?
Posted: Tue Jul 12, 2011 8:41 pm
by nicstrike
rita wrote:Hi,
Cheers.
technically "shock absorbers" aren't ...the springs are. the "shock absorbers" are actually dampers. the spring absorbs the impact and the damper controls the natural tendacy of the spring to continue bouncing.
Re: SHOCKS?
Posted: Wed Jul 13, 2011 12:14 pm
by skater
Cardiff996,
maybe you have lowered springs which ride stiffer than standard.
Re: SHOCKS?
Posted: Wed Jul 13, 2011 3:36 pm
by rita
nicstrike wrote:rita wrote:Hi,
Cheers.
Exactly
