Disc Brake renewal.
Posted: Sun Jul 24, 2011 8:19 pm
Hi Guys,
Recently had to replace front drop links. Whilst doing this job as MOT looming gave the front brakes & suspension a good look over. Well I need to renew the discs/pads and the track rod ends, plus the bottom ball joints (whilst they have no play in them the rubber gaiters are split) need new as well.
Whilst I realise that Ian has many of these parts available I've found better deals on these items supplied by either AVA or Mazda Bongo Shop. As many club members must have purchased from these suppliers & perhaps others (seen loads on E-Bay) can anyone give me any feedback on their experience of quality? Also the price of bottom wish bones at approx £150 a side in order to replace bottom ball joints seems very expensive. You can now get bottom ball joints from Mazda Bongo Shop at £40 each, that's £220 saving if there easy to fit. So, has any one had experience of just fitting the bottom ball joint itself? I expect some sort of press may be needed as I can't quite work out how you would get old one out and new one in.
Now for the disclaimer, I shall not hold anybody responsible for the advice that may be given in good faith if I should consequently follow said advice and not be totally satisfied. I do realise that ultimately it is my choice who I may end up purchasing from.
