check your 18" Accelerra tyres for splits!
Posted: Fri Aug 05, 2011 10:47 am
by rapiddescent
hi folks, I was sniffing around the bongo and noticed that one accelerra tyres (that fit on the rx-8 wheels) had really split badly on the inside edge. luckily I had another rx-8 wheel and changed it immediately.
check yours today! (and then report back if you also have splits)
Re: check your 18" Accelerra tyres for splits!
Posted: Fri Aug 05, 2011 10:53 am
by missfixit70
What pressure is in it? & how old?
Posted: Fri Aug 05, 2011 11:40 am
by teenmal
It looks like that tyre has been run under pressure at some time in its life..
Cheers..
Posted: Fri Aug 05, 2011 12:00 pm
by rapiddescent
yes, could well be. Certainly when I picked up the van a few years ago the tyre pressures were about 30psi! I tend to do for 38/40 or thereabouts. I checked the other tyres and they are OK.
Posted: Sun Aug 07, 2011 12:44 am
by Devonduo
Will adjust mine...Gupa P guessed my new fit to 1.7 Bar on the front and 2.4 rear
Posted: Sun Aug 07, 2011 1:07 pm
by missfixit70
Most people seem to run at least 40psi, the tyre pressures inside the door are the original spec Jap tyres that are apparantly softer compound tyres.
Posted: Sun Aug 07, 2011 7:39 pm
Whats the load rating, out of interest?
Posted: Fri Aug 12, 2011 12:00 pm
by rapiddescent
I think they are either 100W or 102W but certainly say "EXTRA LOAD" on the side.
