Cautionary note - air filter V6
Posted: Wed Aug 17, 2011 3:09 pm
Our V6 has been rough running for the past two or three months - surging/stalling when LPG idling at warm up temperatures but smooth and power good in the normal LPG operating temperature range. Power down, and lumpy at all temperatures and engine load states on petrol. Both getting progressively worse. Seemed to be fairly clearly an EMS control struggle going on, so hoped I didn't have anything major to sort out, e.g., clapped out camshaft or cam followers.
I had changed dizzy cap, rotor arm, and spark plugs to remedy poor starting at the end of last winter, so it was not down to any of them. Coil seemed fine, and there was no sign of ignition harness insulation problems.
The air filter was last changed in 2009 at 79,000 km, and the van had done about 101,000 km when all this started. The air filter service interval is 50,000 km (5.,000 km in handbook is a typo), so it couldn't be that could it?
Well, yes it could! After running some injector cleaner through, which only marginally improved petrol operation, I eventually pulled the air filter element, and found the underside 70%+ choked by internal combustion particulates - smell them, and there's no doubt that's where they came from.
Changed the air filter element, and she now runs silky smooth, loadsa power, no surging, no stalling, on either petrol or LPG - but there is a bit more power on LPG (yes!), due to having slightly increased the plug gaps earlier, as recommended to give a bigger spark for better LPG combustion.
Conclusion - there's probably a lot more particulates around in the air here now, than there were in Japan, when the air filter service interval was specified - so 50,000 km is too optimistic by a factor of 2. Anybody else found the same?
MOT pass today at 104,492 km BTW, no advisories and the usual (lack of) emissions, tested on LPG
