White plug by the handbrake switch ?
Posted: Thu Aug 18, 2011 11:09 am
by tonnee
Noticed last night I had a white plug not connected to anything by the handbrake switch under the centre console, then found a matching white plug tucked under the carpet, any idea what this is for before I connect it up ?
Tony
Re: White plug by the handbrake switch ?
Posted: Thu Aug 18, 2011 11:42 am
by jaylee
I think i know the one!!? (Sort of hanging round part 64-326.)
Do you have working speakers in the back? Though funny enough, from memory it's a two wire connector...?
The speaker Q is sort of relevant....
read somewhere that a connector for the rear speakers was in this vicinity???
Don't quote me.. I would have thought a 4 wire connector? However, it may just be for the drivers side rear...?
by haydn callow
Probably the seat belt warning light.
Posted: Thu Aug 18, 2011 11:45 am
by jaylee
haydn callow wrote:Probably the seat belt warning light.
That's under the drivers seat...
Posted: Thu Aug 18, 2011 11:46 am
by tonnee
its a two wire connection, speakers all work fine Jaylee, I'll check the seatbelt warning light shortly then connect it together see what it does ?
Posted: Thu Aug 18, 2011 11:51 am
by jaylee
tonnee wrote:its a two wire connection, speakers all work fine Jaylee, I'll check the seatbelt warning light shortly then connect it together see what it does ?
Does the seat belt warning currently come on & go out when you strap in with the engine running..?
Scrap my last idea then...
Give me an hour & i can go out to mine & see what stops working when i disconnect...!
Posted: Thu Aug 18, 2011 11:55 am
by tonnee
hahah you know I have never even noticed a seat belt warning indicator
I'll connect it back up at lunchtime and see what lights up before you go unplugging yours then let you know
Posted: Thu Aug 18, 2011 12:03 pm
by jaylee
Posted: Thu Aug 18, 2011 12:12 pm
by jaylee
My adjustable lumber support & back massager stopped working too....!
Posted: Thu Aug 18, 2011 6:14 pm
by missfixit70
jaylee wrote:My adjustable lumber support & back massager stopped working too....!
As did Ady's heated seat
Posted: Thu Aug 18, 2011 11:18 pm
by jaylee
missfixit70 wrote:jaylee wrote:My adjustable lumber support & back massager stopped working too....!
I thought Ady had one of those flashing wiper stalks fitted....?
Posted: Thu Aug 18, 2011 11:20 pm
by missfixit70
Nah it's a wiping flasher stalk.
Posted: Thu Aug 18, 2011 11:24 pm
by jaylee
Of course...! I get them both confused...
