think fuse is gone but which one
Posted: Fri Aug 19, 2011 10:31 pm
by alan
hi hope some one can save me time and hlep i think the fuse as gone on the front 12 v cigar lighters but which one is it can some one ponit me to the right one please
as i need it to work the sat nav in the morning for a trip to wales
Re: think fuse is gone but which one
Posted: Fri Aug 19, 2011 10:37 pm
by missfixit70
If the radio & mirrors aren't working either, then it'll be fuse 8 by the drivers right knee, ie top right in the fuse box. Otherwise it could be on the back of the socket itself -
http://www.igmaynard.co.uk/bongo/forum/ ... it=lighter
Posted: Fri Aug 19, 2011 10:42 pm
by alan
thaks for that i have a look in the morning as the radio & mirrors are working hpfuly i can fix it so we can fine where we staying
Posted: Fri Aug 19, 2011 11:04 pm
by jaylee
If you got a light on the plug/sat nav charger for the cig lighter? Give it a firm push & a jiggle till the light comes on or charge symbol on sat nav... maybe just a connection/continuity issue in the socket? They can do that, especially if they spent years just to light fags.....
Posted: Fri Aug 19, 2011 11:09 pm
by alan
jaylee wrote:If you got a light on the plug/sat nav charger for the cig lighter? Give it a firm push & a jiggle till the light comes on or charge symbol on sat nav... maybe just a connection/continuity issue in the socket? They can do that, especially if they spent years just to light fags.....
yeh that what i thought but try that and no luck os thinking it a fuse
if i cant fix it in the morning can you get a lead so i could plug it in to the 12v socket that runs of the LB about 1/2 way down the side of the bongo???????????
Posted: Fri Aug 19, 2011 11:17 pm
by jaylee
alan wrote:jaylee wrote:If you got a light on the plug/sat nav charger for the cig lighter? Give it a firm push & a jiggle till the light comes on or charge symbol on sat nav... maybe just a connection/continuity issue in the socket? They can do that, especially if they spent years just to light fags.....
yeh that what i trhought but try that and no luck os thinking it a fuse
Mines a bit like that.... Great for lighting fags though!!
I now have fitted a designated socket fitted out of sight, under the dash.. Keeps the sat nag wire out the way... comes out here, just below the dial pod on the a pillar...
Just sticking out from dash edge.
Tucked out the way when not in use.. Pull out when wanted!
Posted: Fri Aug 19, 2011 11:20 pm
by alan
jaylee wrote:alan wrote:jaylee wrote:If you got a light on the plug/sat nav charger for the cig lighter? Give it a firm push & a jiggle till the light comes on or charge symbol on sat nav... maybe just a connection/continuity issue in the socket? They can do that, especially if they spent years just to light fags.....
I now have fitted a designated socket fitted under the dash.. Keeps the sat nag wire out the way... comes out here, just below the dial pod on the a pillar...
that looks a nice idea
Posted: Fri Aug 19, 2011 11:31 pm
by jaylee
thanks!
Not a big fan of trailing wires...
Ran a spur off the cig, radio, mirror loom.. Socket under the steering wheel behind the panel under the cowl, plenty of slack on the charger wire to pull out when needed & stick the nav to the window just above my gauge...
Just a thought... Some sort of leisure battery fitted??
