Hose fact sheet
Posted: Tue Sep 27, 2011 3:06 pm
by widdowson2008
Can someone tell me who produced this fact sheet please?
http://www.igmaynard.co.uk/bongo/member ... /hoses.pdf
Re: Hose fact sheet
Posted: Tue Sep 27, 2011 3:24 pm
by Ian
Me, mostly. Why?
(Edit: actually the original was done by Matthew in Sept 2010, based on info here on the Forum and elsewhere, but latest amendment, which incorporated a couple of Steve's useful schematics, was done by me)
Re: Hose fact sheet
Posted: Tue Sep 27, 2011 3:42 pm
by widdowson2008
Hi Ian
The schematics are CURRENTLY being modified. Errors pointed out to me very recently which I am rectifying.
Factsheet also omits certain hoses which I have addressed. If we are going to have one, then let's get it right. :wink:
When I originally posted those sketches, I asked for someone to step up and check them for me. Never happened, and as a result we finished up with some errors. Not going to happen again. :wink:
Re: Hose fact sheet
Posted: Tue Sep 27, 2011 3:45 pm
by Ian
Ok Steve, no problem. If I email you the master template of the factsheet (Word copy) will you make the required amendments and send it back?
Re: Hose fact sheet
Posted: Tue Sep 27, 2011 3:50 pm
by widdowson2008
Ian wrote:Ok Steve, no problem. If I email you the master template of the factsheet (Word copy) will you make the required amendments and send it back?
No problem Ian, but I would like it checking before publishing. Let's get it absolutely right.
Who do you think is the best person for the checking job?
Re: Hose fact sheet
Posted: Tue Sep 27, 2011 4:05 pm
by Ian
The issue of quality reviewing the factsheet series has been raised before, and now's as good a time as any to take it forward. So I've stated a new topic at http://www.igmaynard.co.uk/bongo/forum/ ... =4&t=51919
Re: Hose fact sheet
Posted: Sun Oct 09, 2011 10:59 am
by widdowson2008
First of all - apologies for previous errors. Totally my fault for not having them checked.
A comprehensive coolant hose and fact sheet has now been produced which lists the hoses, steel pipes, and steel clips.
It includes all the Mazda part variants of hoses which relate to specific year of production of the vehicle.
The sheet provides links to related associated cooling system issues such as coolant changes, coolant type, bleeding method, low coolant alarms, etc.
This version is currently being checked (for the umpteenth time) and will be issued as soon as possible.
It uses marked-up Lush project diagrams (6 in all including a table) as a basis for members who are familiar with them, as per the following diagram:
Many thanks to those involved in checking these. Would not have happened without them. =D> =D>
Because I was asked, a separate (and simplified) version has also been produced based on the following diagram (5 in all including a table):
Both versions include this table of parts:
Re: Hose fact sheet
Posted: Sun Oct 09, 2011 11:47 am
by TerryG
Fantastic stuff!
How different is the pipework for the V6?
Re: Hose fact sheet
Posted: Sun Oct 09, 2011 12:02 pm
by widdowson2008
TerryG wrote:Fantastic stuff!
Not too sure but I'm sure the vast majority of it will be common. When I get a spare moment I'll run a check (unless someone else has some spare time on their hands) [-o<
edit: just done a VERY quick search. Some are different, particularly around the thermostat area. However, I think the 'comprehensive' factsheet may cover it (although the diagrams are slightly different.)
I was rather hoping I had seen the back of this but I may need to create one for the V6. :evil:
Re: Hose fact sheet
Posted: Sun Oct 09, 2011 12:47 pm
by widdowson2008
Just been pointed out to me by a razor sharp eye that the Lush diagram above should have been this one. Only a minor difference - can you spot it?
Re: Hose fact sheet
Posted: Sun Oct 09, 2011 2:16 pm
by TerryG
But think of the gratitude of we V6-ers - surely a reward in itself :D
Re: Hose fact sheet
Posted: Sun Oct 09, 2011 5:57 pm
by haydn callow
V6..the two BIG inlet/outlet from the rad are the same....the two big ones into the head and stat are differant.
Re: Hose fact sheet
Posted: Mon Oct 10, 2011 10:04 am
by maxi_77
Some of us are stuck with 2 litre Bongos how do they compare to the diesel/V6 versions. Thanks
Re: Hose fact sheet
Posted: Mon Oct 10, 2011 11:10 am
by widdowson2008
maxi_77 wrote:Some of us are stuck with 2 litre Bongos how do they compare to the diesel/V6 versions. Thanks
Not sure, but I would guess that the main hoses are the same. I would expect differences to occur leading up to, and around the thermostat area. Don't know if the heater layout is the same either.
I was going to have a go at the V6/2 litre models, but it has been quite rightly pointed out to me (having a diesel myself) that unless you are familiar with the petrol layouts, the chances of getting it right are low. Someone else needs to pick the baton up at this point I'm afraid - sorry.
Re: Hose fact sheet
Posted: Mon Oct 10, 2011 11:17 am
by missfixit70
Have a look on lushprojects, should give you an idea, It looks to me like more than half are the same from what I've seen before, it's the bits "local" to the engine that seem to be different. The heater layout should be the same as on the heater circuit on Lush it gives options for the hoses that connect from circuit to the engine for the 2litre & 2.5v6.
