Removing cubby below radio
TerryG
Post by TerryG » Tue Oct 18, 2011 9:48 am
Can anyone tell me how to remove the cubby box in the bottom half of the double DIN radio console?
'Enjoy every sandwich'
Velocette
Re: Removing cubby below radio
Post by Velocette » Tue Oct 18, 2011 10:04 am
TerryG wrote:Can anyone tell me how to remove the cubby box in the bottom half of the double DIN radio console?
If you remove the side covers underneath it which are held on by plastic rivet things IIRR there is a metal bracket or brackets that it is fixed to right behind it. I haven't had mine out but I had a look behind before drilling a hole for my temp alarm cable.
Post by Northern Bongolow » Tue Oct 18, 2011 10:49 am
it doesnt come out :evil: or it can, but its a one way trip :)
Velocette
Post by Velocette » Tue Oct 18, 2011 10:53 am
Northern Bongolow wrote:it doesnt come out :evil: or it can, but its a one way trip :)
In that case the bracket probably supports the centre of the dashboard via the cubby box shell.
TerryG
Post by TerryG » Tue Oct 18, 2011 10:57 am
I want to remove it to replace it with a BMW clock/cubby so I'm not too worried about damaging it - though I might be if I can't get the clock to fit!
Velocette
Post by Velocette » Tue Oct 18, 2011 11:15 am
You may need to make up some bracketry to support the dash. It is a few months since I had my head under there but thinking back I think the box is a structural part of the das hand bolted to a bracket on the tunnel under the heater.
I could be wrong, someone will soon be along who knows more.
carlioll
Post by carlioll » Tue Oct 18, 2011 11:17 am
I am a bit confused here. I have had my cubby box out many times without any dificulty. I just remove the glove box and then press the cubby box sideways and forwards at the same time. It just pops out` -no screws, scrivets or anything else holding it. However, if you are referring to the cubby box down by the gear lever then thats a different matter altogether.
TerryG
Post by TerryG » Tue Oct 18, 2011 12:25 pm
carlioll wrote:I am a bit confused here. I have had my cubby box out many times without any dificulty. I just remove the glove box and then press the cubby box sideways and forwards at the same time. It just pops out` -no screws, scrivets or anything else holding it. However, if you are referring to the cubby box down by the gear lever then thats a different matter altogether.
It's just the DIN sized box below the radio I'm referring to. For clarification, there are two DIN alcoves, the top one of mine has a single DIN aftermarket radio fitted, and immediately below it is a recessed box/cubby - that's the one I want to remove.
Bet you can guess the next question! How do you remove the glovebox? :)
carlioll
Post by carlioll » Tue Oct 18, 2011 1:43 pm
you can get at the cubbybox without actually removing the glove box. Just open the glove box and you can get your arm in there OK...
The glove box isnt difficult to remove -there are some plastic lugs on the side of the box and you just have to press the box hard to one side and get the lugs to clear -have a look and you will see what I mean.
TerryG
Post by TerryG » Tue Oct 18, 2011 1:45 pm
carlioll wrote:you can get at the cubbybox without actually removing the glove box. Just open the glove box and you can get your arm in there OK...
Great - many thanks :D
Diplomat
Post by Diplomat » Tue Oct 18, 2011 7:29 pm
My radio is in the lower space with the cubby above it.
Frank
They flew, I took up naturism
Velocette
Post by Velocette » Tue Oct 18, 2011 8:24 pm
Ah sorry, I thought you meant the black hole thing in the middle
