New Head Gasket Blanking 3 Water holes
Posted: Sat Oct 29, 2011 1:31 pm
Hi, I'm fairly new to the Bongo world and had to do a head gasket as I had a small pin-prick coolant leak and my garage didn't bleed the system properly afterwards, leading to air locks and an overheated engine.
I had the head pressure tested and skimmed and when we put the new gasket on, there are 3 water holes blanked out by the new gasket. Unfortunately we threw away the old gasket to check. Is this normal? It's a 2.5 td.
On images i have seen new cylinder heads without the 3 water holes i speak of and other that have them as per my head. It doesn't sem right to have the gasket block the flow of water.....
Any help would be greatly appreciated.
Dave
Dave
