Fuel Filter
Posted: Fri Dec 16, 2011 9:48 am
by cardiff996
Hi all,
I have a diesel Bongo 96 reg.
I noticed that the fuel filter has been disconected and an inline filter put in its place.
Am I simplifying things to think that a filter is just a filter.....after all the inline filter has a mesh in it so it will stop any particles and therefore do the job??
Anyone else have this set up or any opinions from the experts?
Cheers Gang
Re: Fuel Filter
Posted: Fri Dec 16, 2011 12:14 pm
by teenmal
Hi cardiff996,
The standard manufacturers fuel filter is a wee bit more than just a filter,it has a sediment/water trap and a warning system incorporated.
Cheers.
Re: Fuel Filter
Posted: Fri Dec 16, 2011 1:33 pm
by Simon Jones
The proper filter unit has a moisture trap & sensor to indicate you have a build of of water in the bottom, as well as the ability to drain off the moisture. Presumably Mazda fitted this instead of a cheap in-line filter for a reason, so my recommendation would be to investigate why it has been bypassed & consider reconnecting it back up. If you find there is a fault with the filter assembly, I have a spare one available in exchange for some beer tokens ;)
Re: Fuel Filter
Posted: Fri Dec 16, 2011 2:10 pm
by jaylee
Re: Fuel Filter
Posted: Thu Dec 22, 2011 11:01 am
by cardiff996
Hi all,
Thanks for the info and sorry for the delay in replying.
I think I will take the advice and look to connect the filter back on to the fuel lines. Wont drive to far though in case it conks out!!
Re: Fuel Filter
Posted: Fri Dec 23, 2011 1:44 am
by The Great Pretender
How long have you had the Bongo?
If the previous owner was such a tight ass that he wouldn't replace the filter or bypassed a warning light alarm bells should be ringing.
If I were you I would take it to a Bongo specialist and have a full service and health check. :wink:
