Head Bolt Torque Settings
Posted: Wed Jan 25, 2012 3:22 pm
I've just had a member on the phone who has queried this info which can be found in the "Head Gasket" factsheet:
The assembly procedure simply reverses the disassembly, which is the reverse of the disassembly, but the head bolts must be torqued up correctly, 10nm then 29nm plus two 90-degree turns: all in stages, one after the other. I could not find the head-bolt tightening sequence so I followed the standard procedure starting in the middle radiating clockwise one after the other. Use Tippex to mark the one you have just done, as it is very easy to get lost amongst 16 of the pesky things. Once torqued up to 29nm they then each need two additional 90-degree additional turns; again use Tippex.
These seem very low. Can someone confirm that they are correct? I'm away from the office at the moment and don't have access to the workshop manual............
