Paintwork- lacquer or lack of muscle?
Posted: Sun Feb 26, 2012 11:20 pm
by onewheeltoofew
Can anyone help me with an issue I've got with the paintwork on my van, just above the windshield?
This is the best picture I could get of it, but you can sort of make out the problem. The colour seems to have faded and gone dull (it's most obvious in the Sunshine-so not often a problem then
). It looks like old oxidised paintwork but using T-cut doesn't seem to help improve it and I don't want to go too heavy with the abrasives. So before I break out the elbow grease, is it more likely to be a problem with the lacquer and what's the best way to fix it?
Col
Re: Paintwork- lacquer or lack of muscle?
Posted: Sun Feb 26, 2012 11:36 pm
by Northern Bongolow
Posted: Mon Feb 27, 2012 12:11 am
by onewheeltoofew
Just need to get some for the auto free top a la Dodgey's excellent thread and we'll be properly self sufficient.
Posted: Mon Feb 27, 2012 9:52 am
If you wet the surface, does the colour come back or can you still see the fault?
Posted: Mon Feb 27, 2012 11:47 am
by onewheeltoofew
Hmmm, I'm not sure. I'll check when I get back from work. Out of interest, What would it mean if the colour came back?
Posted: Mon Feb 27, 2012 6:57 pm
by lpgimports
Its basically sunburnt, the clear coat has been affected by the heat over its life and is scorched. some polishes will make it look a little better for a short time but the only long term cure is to repaint the affected areas and blend into existing
Paul
Posted: Mon Feb 27, 2012 8:10 pm
by onewheeltoofew
Cheers for the info Paul.
When you say repaint, could I just take off the clearcoat and reapply (being careful to blend it in) or is it a case of taking it right back to the metal and starting again?
Posted: Mon Feb 27, 2012 8:19 pm
by lpgimports
The problem is all paints fade at different rates, it is possible to lightly flat the surface and clear over it again and sometimes the wet clear will lift the faded dry paint, sometimes this works sometimes need to add a bit of matting agent as ultra glossy clear when all the rest around it slightly dry and faded stands out too much, worst case it you clear it and all the edges show up like an old map and it needs to be properly flatted back and repainted.
Paul
Posted: Mon Feb 27, 2012 8:39 pm
by onewheeltoofew
Fair do's, I'll try a little section first to see if it makes any diffference before handing it over to the professionals.
Posted: Mon Feb 27, 2012 9:06 pm
by cabte
lpgimports wrote:Hi
Paul
yep iv seen this on a lot of bongos,
Posted: Mon Feb 27, 2012 10:18 pm
lpgimports wrote:The problem is all paints fade at different rates, it is possible to lightly flat the surface and clear over it again and sometimes the wet clear will lift the faded dry paint, sometimes this works sometimes need to add a bit of matting agent as ultra glossy clear when all the rest around it slightly dry and faded stands out too much, worst case it you clear it and all the edges show up like an old map and it needs to be properly flatted back and repainted.
Paul
Great advice from Paul and its all much as I suspected. You might get an acceptable and simple fix if you can find natural body lines to work up to as a panel, esp if the sprayer can melt the join line from old to new. I think there is a whole bag of cosmetic tricks possible by just relacquering instead of doing a full paint job.
Posted: Tue Feb 28, 2012 6:54 pm
by Lotustuart
This was my Spoiler before I polished it
And this is after a bit of TLC!
Always worth a good old polish before you spend out on a respray. IMO.
Posted: Thu Mar 01, 2012 4:22 pm
by tonnee
My silver Bongo is exactly the same, never tried to polish it out though, might try this year !
Posted: Mon Mar 12, 2012 1:21 am
by Paulinwales
I had a similar problem and found spraying with clear laquer sorted it out! might be worth a try, perhaps using rubbing compound as well - try a small section first.
rgds Paul
