RAC European break down cover
Moderator: g8dhe
expensive but comprehensive, is it worth it (£165.00)........ anyone had a break down experience in Europe using the above?
Hollis
Re: RAC European break down cover
Far too expensive. I have cover with 2gether which cost £67.50 for full UK and EU cover.
Called them out once in the UK and the guy they sent was very good.
Derek
Derek
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Hollis wrote:Hi
Derek
X2 just insured l'oreal with 2gether fully comp protected ncb and euro breakdown cover £350, i'm one very happy camper
- Simon Jones
Is that £165 for a year or single trip? I seem to recalling spending about £70 with Europ Assist but that was for a single excursion. If I was planning on going more often I would consider an annual policy. I've only had to call on their services once and I can't fault they way they handled everything and even called me later to check I got home ok.
________________________________________________________________________________M 80NGO wrote:Hollis wrote:Hi
Derek
X2 just insured l'oreal with 2gether fully comp protected ncb and euro breakdown cover £350, i'm one very happy camper![]()
With respect, most people do not take the time to read the 'deadly' small print which in a lot of cases has more 'grey areas' than the hair on my head
Hollis
Yes thanks I can read large and small print. In fact there is very little "small" print. There is a limit to six breakdowns per year. Losing keys or running out of fuel is not covered. Keys locked in vehicle not covered. Any immobilsation that is not either electrical or mechanical is also not covered. The cover looks pretty good to me.
As I said I have called them out once and they sent a guy that knew his stuff. This guy worked for a good hour and got me going again. Did not cost me one penny. What more do you want hopefully not blood!
Derek
Derek
RAC, annual tripSimon Jones wrote:Is that £165 for a year or single trip? I seem to recalling spending about £70 with Europ Assist but that was for a single excursion. If I was planning on going more often I would consider an annual policy. I've only had to call on their services once and I can't fault they way they handled everything and even called me later to check I got home ok.
- Simon Jones
RAC policy details look pretty straightforward. It mentions vehicles should not be over 6 years old at start of journey, but older vehicles will be covered for an additional cost. Couldnt see anything about the common 15 year restriction which can be an issue for the older Bongos.
http://media.rac.co.uk/pdf/ebc-policy.pdf
How old is your vehicle though? I can't seem to find any comprehensive cover for less than 180£ single trip.Hollis wrote:Hi
Derek
Hollis
It is on an X plate. First registered Oct 2,000 in Japan.
It is funny because I clean and polish it more than my car or bike both of which I bought new. Must be bongo madness!.
Derek
Derek
Simon Jones wrote:RAC policy details look pretty straightforward. It mentions vehicles should not be over 6 years old at start of journey, but older vehicles will be covered for an additional cost. Couldnt see anything about the common 15 year restriction which can be an issue for the older Bongos.
Yes, I looked at that (page 15) and in my case I'm waiting for them to confirm (within my quote cost) that I have meet all the criteria's of the policy.. as i said in the other post one does have to dissect the 'small print'...shame though
wicksie
This is strange because i got a quote for annual cover for £252 which went down to £183 when I gave them my N plate reg.Simon Jones wrote:RAC policy details look pretty straightforward. It mentions vehicles should not be over 6 years old at start of journey, but older vehicles will be covered for an additional cost. Couldnt see anything about the common 15 year restriction which can be an issue for the older Bongos.
I'm a bit put off by their one call out only limitation, so waiting to see what I get with the AA's £284 quote.
No answer all day at 2gether.
