Hello chaps,
Can anyone recommend a suitable engine oil for my Bongo 1996 that has covered 70,000 miles? It is only for topping up the engine oil, not replacing. I am also planning to cover a lot of miles very soon, MOT and service due end of September. Don't know if that makes any difference to choices!
Thanks much in advance, haven't a clue with these things as you can tell
Steve
P.S. Cannot find the 10W/30 oil recommended in the fact sheet anywhere!
Recommended Engine Oil 1996 70,000 miles
- rhino-wayne
Re: Recommended Engine Oil 1996 70,000 miles
digitalgypsy wrote:Hello chaps,
Steve
If you don't know what oil is in the Bongo...I guess it wont really matter which oil you use!?
Have you changed the oil since purchasing?
There is plenty in the forums about oils...do some searching........finding oil can also be the same....a bit of a search
Thanks for the above advice...
I did search the other posts but saw differing opinions so got lost!
Am considering this: http://www.halfords.com/webapp/wcs/stor ... yId_165581 If anyone can let me know if it's suitable then please do!!
5w/30 is also OK
http://www.wilkinsonplus.com/car-mainte ... a9qg%3D%3D
Synthetic - buying 3x2lt is enough for a full change.
Or
http://direct.asda.com/ASDA-5W30-Semi-S ... c=PPCXSLTP
Semi synthetic. you'll need more than 1x5lt though for a full change.
Or
Will this do? The more I read the more I get confused on this topic.
http://www.halfords.com/webapp/wcs/stor ... pping#tab2
It's never too late to have a happy childhood.
Most garages bung 10W/40 Shell Helix in because it's what they bulk buy. I've always used that with no problems.
lidl's...awesome stuff.
