Page 1 of 2
Excess engine oil
Posted: Sun Aug 26, 2012 3:30 pm
by hopey
Hi, I'm a complete novice when it comes to engines etc, I've had my Bongo for 4 months and finally looked at the engine to check the oil.,I found a fair bit of oil on the engine (only on the passenger side), is this something to worry about? It looks like it's coming from the engine?
http://www.flickr.com/photos/85826914@N ... hotostream
Re: Excess engine oil
Posted: Sun Aug 26, 2012 3:50 pm
Not uncommon, they can be quite oily engines. It's probably leaking from the rocker cover (for as much as I can tell from the pic, on my small phone). I gunked mine clean and tightened the bolts just a little in the area it seemed to be coming from. No problems since.
Posted: Sun Aug 26, 2012 3:51 pm
by Northern Bongolow
it looks like the rocker cover gasket.
wants doin
the bolts go through a spacer tube through the gasket, this hardens over time.
the fury shop sells a good replacement with new tubes/gasket, or you can cheat----grind a few mm off the old tubes and refit.
Posted: Sun Aug 26, 2012 3:58 pm
by hopey
Cheers for the replies.
Is it a big problem and is it something that I need to get sorted asap?
It's still ok to drive?
Posted: Sun Aug 26, 2012 4:08 pm
looks ok for a bit, but i would do it.
keep a check on the oil level.
Posted: Sun Aug 26, 2012 4:11 pm
by hopey
cheers I'll try and find a bongo specialist close to me.
Just hope it's not an expensive job
Posted: Sun Aug 26, 2012 4:15 pm
by francophile1947
hopey wrote:cheers I'll try and find a bongo specialist close to me.
Do as mikeonb4c says first - takes a few minutes and it's free
Posted: Sun Aug 26, 2012 4:20 pm
Shouldn't be. I go to Adrian at Japan Direct in Bury 0161 763 3003. He is excellent with Bongos, good on price, and may get a gasket (if it needs one) cheaper than the Bongo Shop. And you can enjoy Bury Market while he does the job.
Posted: Sun Aug 26, 2012 4:22 pm
may need to check out jaylees ac compressor question thread too, as yours has a bolt through on the alternator adjuster.
Posted: Sun Aug 26, 2012 4:29 pm
by hopey
mikeonb4c wrote:hopey wrote:cheers I'll try and find a bongo specialist close to me.
Great thanks, I'll give him a ring Tuesday
by hopey
Northern Bongolow wrote:may need to check out jaylees ac compressor question thread too, as yours has a bolt through on the alternator adjuster.
Now you have really lost me? ha ha
Posted: Sun Aug 26, 2012 4:34 pm
by hopey
francophile1947 wrote:hopey wrote:cheers I'll try and find a bongo specialist close to me.
OK will give it a go, I'm not famed for my DIY skills
Posted: Sun Aug 26, 2012 4:50 pm
hopey wrote:francophile1947 wrote:hopey wrote:cheers I'll try and find a bongo specialist close to me.
Be careful then, you don't want to over tighten the bolts and crack the rocker cover. Just a gentle tighten. . If in doubt, contact Adrian
Posted: Sun Aug 26, 2012 10:57 pm
in the picture you posted of your bongo engine i notice that your alternator belt adjuster is missing, it has been replaced by a nut and bolt.
Posted: Sun Aug 26, 2012 11:54 pm
by jaylee
hopey wrote:Northern Bongolow wrote:may need to check out jaylees ac compressor question thread too, as yours has a bolt through on the alternator adjuster.
What Ady means is you have this missing from your alternator assembly...
..& so do i now. Broke it this morning..
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=57295
