Electrics
Posted: Wed Sep 12, 2012 3:52 pm
by malc_s
Can youse please help with a couple of queries I`ve got re. electrics.
1) If I run my Waeco fridge off the leisure battery until its flat, will the fridge continue to draw from the main batt. until that is also flat or is there some sort of protection to prevent this happening?
2) Is the Osram Nightbreaker bulb a direct replacement for existing H4 headlamp bulb, ie how hot does it run, is it likely to melt/ make brittle existing wiring insulation?
Just booked in for second MOT, fingers crossed.
Malc
Re: Electrics
Posted: Wed Sep 12, 2012 4:07 pm
by Velocette
malc_s wrote:Can youse please help with a couple of queries I`ve got re. electrics.
Malc
I have run my 3way fridge experimentally on my leisure battery until it was virtually flat and the starter battery was unaffected. i then charged it with a mains charger. I have a Wilington kit but it should be the same with any split charge relay.
Re: Electrics
Posted: Wed Sep 12, 2012 5:51 pm
A correctly installed leisure battery system will NOT allow anything to switch over to the Starter battery without user intervention !
Its the the prime function of the L/B system to make sure that the S/B can't be flattened!
Some systems will allow the user to select which battery to use, but it is most definitely meant to be a user choice, however some of the control panels can be very confusing.....
Re: Electrics
Posted: Thu Sep 13, 2012 7:35 pm
by malc_s
Thankyou for prompt reply, they were very helpful.
Aren`t forums great.
Malc
Re: Electrics
Posted: Thu Sep 13, 2012 7:46 pm
by Northern Bongolow
nightbreakers are a straight swapover, i ran them for a couple of years with no problems. nice white light too.
try these though, they are even better, RING xenon ultima. 8) :wink:
Re: Electrics
Posted: Thu Sep 13, 2012 7:56 pm
by Simon Jones
Running a battery, especially lead acid until its flat, will cause the plates to bend so they short out and then it will no longer hold full charge. Warm beer is better than a ruined battery.
