Diesel leak
Posted: Sun Feb 10, 2013 8:51 pm
by Gannet
Would welcome an opinion before I take Bongo to garage tomorrow.
Very strong hot diesel smell after relatively short run. Fuel dripping onto undertray and dropping on drive. Recently had fuel pump seals replaced after leak from this area (now ok) but now noticed leak from far left glow plug (?) top of engine above injectors (viewed from Driver's side). Diesel heating up on hot engine and smoking when I took a look! Engine has been lumpy on start up recently but runs fine when warm.
Is it a question of tightening up plug or would a new set of plugs be appropriate? Am I on the right track?
Any help gratefully received.
Re: Diesel leak
Posted: Sun Feb 10, 2013 9:14 pm
by the laird
Sounds like a burst injector pipe,if it is Simon jones has a set up for sale grab them .if the inj pipe is burst with the seats raised and eng running you should be able to see a leak or spray from the pipe
this could cause a misfire
Hope this is of help
Re: Diesel leak
Posted: Sun Feb 10, 2013 10:18 pm
by Simon Jones
I've been trying to find a good home for these for a while, so let me know if they are what you need:
http://igmaynard.co.uk/bongo/forum/view ... 68&t=59278
Re: Diesel leak
Posted: Sun Feb 10, 2013 10:20 pm
by Northern Bongolow
if the glow plug is loose, (the torque setting is very low) you could get fuel blown back up and out. or the thread is damaged.
when i put them in i test them with fairy liquid they often leak, although they have quite a long thread only half goes into the head.
