internal diagram of fuel pump.
bongoshotts
- Apprentice Bongonaut
hi ,Billy has had yet another Diesel leak after fixing the first one and putting it back together then taking 2 days getting it to start again it is still leaking so need to replace the large o ring.... does anyone know how to re-build the pump? we can't find any pictures of the internal bits so we can rebuild. it. the 0 ring looks ok but a man down the road thinks it should be protruding more.the pump is now across the kitchen table and don't know which bit goes where???????? help.
Re: internal diagram of fuel pump.
Hi,if you mean the distributor body O ring this can be replaced without striping the pump.
If you have striped the pump PM me your email address and I will send you some pics.
- mikexgough
