please can you let us have the fault codes on the mazda bongo as we have a fault code of 9 and 62. chamged solenoid in gearbax as 9 engine coolant light 62 overrun clutch solenoid
what is best solution
bopngo fault code
Re: bopngo fault code
julian on page 80 of the bongo manual it gives info on how to test the clutch solenoid, and 82 gives the temp sender test figures. these are voltage tests done at the ecu to establish voltage.
if you need more info i have pm'd my phone number.
