I'm looking at booking at a campsite in France and have the option of either 6 amp or 10 amp hook up.
Excuse my ignorance, but am I right in assuming that the only difference is the number of things you could have running off the supply at any one time or should I definitely choose one over the other?
Thanks in anticipation of your help.
EHU - 6AMP or 10AMP
Moderator: g8dhe
Re: EHU - 6AMP or 10AMP
Yes you are correct it is the load that can be applied before the trip shuts off the power.
6A x 240V = 1440W or 1.4kW
10A x 240V = 2400W or 2.4kW
Before some smart Alec points it out these are approximate because I haven't allowed for the power factor due to it being AC current.
- bongojoe
Unless you want to run an electric heater or oven, you'll probably be fine with 6A - plenty to charge a computer or batteries, run a TV or radio. Every appliance should tell you its wattage somewhere, so add them up and use the numbers above.
1999 2WD 2.5L Diesel AFT
Thanks very much for your help.
Difficult to run a kettle or toaster on 6amp.bongojoe wrote:Unless you want to run an electric heater or oven, you'll probably be fine with 6A - plenty to charge a computer or batteries, run a TV or radio. Every appliance should tell you its wattage somewhere, so add them up and use the numbers above.
- helen&tony
Go for 10A...
1/. They're often not what they say
2/. If there are several sockets on one pole, and there are other campers on the same pole, you'll be lucky to run a coffee grinder
Go for 10A...
Thanks again everyone for your ever helpful advice. I've just re read the booking slip and the difference between the two is 1 Euro a day, so 10amp it'll be!
