Turbo Air Intake - corrugated pipe - 2.5TD 1996
while sorting out the new radiator I had cause to remove the plastic intake pipe to the turbo --I found that it leads to a corrugated pipe that goes round the back of the engine to meet the Turbo inlet---- on looking into the engine bay, near side, the turbo corrugated pipe is clearly split and past it's best. has anyone found a source for new corrugated pipe section??
Re: Turbo Air Intake - corrugated pipe - 2.5TD 1996
The corrugated pipe that you refer to is a type of heat shield, they are split for fitting and removal purposes. If the turbo pipe itself was split you would soon know about it.
Good Luck.
Good Luck.
