Getting to the end of my tether with it!
dave_aber
Re: Getting to the end of my tether with it!
Post by dave_aber » Sat Mar 15, 2014 11:28 am
Re the Vacuum accumulator - I may have mis-remembered this as a plastic ball (Like VAG Central locking systems have).
Lushprojects show it as a cylinder, 43-760 on this drawing.
I was sure the one I'd looked at was a sphere - which made me think it was an accumulator, but lush says otherwise.
Either way, this drawing shows the parts of the vac piping and valves etc - lots to cause trouble there!
HTH
Dave
Image...Image
Gandalf The White
Post by Gandalf The White » Wed Aug 02, 2023 9:48 am
Hi there.
I had a longstanding problems with our 2002 Diesel Bongo with the dreaded going into limp mode and glow plug light flashing once engine was warm and sat in traffic. I cleared all the old fault codes and found the two fault codes being displayed were P0400 and P1228. Spent hours researching this trawling for answers through the forums, FB groups and it's also well detailed on the Wastegate Actuator factsheet in the members section. It's obvious people have spent hours on this, but nothing seems to give a permanent guaranteed long term fix. After much head scratching I discovered Mark at The Bongo Master in Leicestershire, really good, decent, honest bloke, who knows Bongos inside and out, he has great reviews from all his customers. Mark immediately knew what the problem was. It's a known issue with later Bongos, due to combination of a change of turbo design and poorer quality grade diesel in the UK. Mark charges £600 to retrofit an older turbo from an earlier model and changes the relevant ducting and piping to go with it. The van then ran as sweet as a nut, with no loss in performance at all. Just thought I'd share, as it could save somebody alot of time, money and hassle in the future.
https://www.thebongomaster.co.uk/
